Results 41 to 50 of 77
June 30th, 2014 06:58 AM #41
- Jun 2006
- 1,139
June 30th, 2014 10:39 AM #43Even my 1.5g vios has that throttle lag, its just not that noticeable on automatic versions
- Jul 2013
- 2,450
June 30th, 2014 10:52 AM #44
- Jul 2013
- 2,450
June 30th, 2014 10:54 AM #45
- 52,731
June 30th, 2014 07:50 PM #46
- May 2014
- 1,318
June 30th, 2014 08:04 PM #47It is true that emission tests is valid for 2-3 months only. It is indicated in the test certificate for use.
http://www.emb.gov.ph/portal/Portals...010-23_628.pdf
However, what you sometimes forget is that:
1) you can say no to them doing the actual emission testing as the car operator/driver. They can be prevented from riding your vehicle to operate the accelerator. You can do it yourself you know.
2) check annex b in the pdf link. page 7 of their brief. Item 4 Test procedure Letter d states they should pump the accelerator 2-3 times first to remove any deposits in the exhaust pipe prior to actually obtaining the test sample/result.
3) Below is the actual test procudure as per EMB rules regarding the obtaining of test results.
e. With the engine idling, depress the accelerator quickly, but not violently, to obtain maximum delivery
from the injection pump. Maintain this position until maximum engine speed is reached for about two (2)
to four (4) seconds and the governor comes into action. As soon as this speed is reached, release the
accelerator until the engine resumes its idling speed. Record the maximum reading of the smokemeter.
f. The operation described in paragraph (4)(e) shall be repeated not less than six (6) times in order to
clear the exhaust system and to allow for any necessary adjustment of the apparatus. The maximum
opacrty values read in each successive acceleration shall be noted until stabilized values are obtained.
The values read shalt be regarded as stabilized when four (4) consecutive readings are within a hand
width of 0.25 m-1 and do not form a decreasing sequence. The arithmetk mean of the four stabilized
values shall be the test result for the concerned vehicle.
Tanong ko lang, may gumagawa ba ng tamang procudure sa emission testing?
- 52,731
June 30th, 2014 08:18 PM #48yes, i am aware that the lifespan of the test emissions certificate is only 3 months. that is why we have to time the test, for the annual registration.
but are we really required to drive around the city with an updated certificate? are we required to have our rides tested every 3 months?
- May 2014
- 1,318
June 30th, 2014 08:48 PM #49No you are not required to keep one in tow everytime that is valid as they can always conduct the test via the ASBU team scattered in whatever hiding place they selected.
That is the reason why the ASBU can test to see whether you are violating the max smoke emissions, heck they even do that even with a valid certificate sometimes (for those who are just hungry to catch for quota).
So you have to keep in mind the guidelines of how testing is done as I linked above. How can they say that you did violate the emissions limit if they do not have equipment? Seeing black soot coming out is not an immediate sign of failure in emission testing as the test itself provides for throttling 2 to 3 times to remove soot deposits in the exhaust system prior to actual testing. And testing is done not 1, not twice, but 6 times to make sure that any loose deposits is released from the system and the result are based on consistent data. So keep the EMB guidelines in tow. Which is why I posted the link for everyone to refer to if they have any questions on how the testing should be done.
Violent depression of the accelerator is a no-no as no matter how good the diesel engine is, it will surely emit deposit as the engine was unable to keep up with the sudden demand for diesel and unable to burn it properly from the get go. (Again refer to the test procedure).
- 52,731
June 30th, 2014 08:59 PM #50from what i understand,they can not just single out any vehicle for no reason at all. there must be a reason, e.g., dark smoke seen exiting from the tailpipe..
Daming issue ng SU7:grin:
Xiaomi E-Car
