Results 1 to 8 of 8
April 19th, 2011 09:16 PM #1
mga paps, share ko lang na experience ko sa unit ko last sunday. i own a 2011 innova G D4D. nagsimba kasi kami, so i parked. tagal lang naka idle engine ko ng hindi pa ako nakaka park kasi ang tagal lumabas ng mga sasakyan nung unang mass kasi palm sumday diba, masikip. kaya medyo matagal akong nag antay. nung naka park na ako in-off ko na engine tapos bumaba na ko sa sasakyan. nung i llock ko na, i pressed the lock button in the remote of the key, hindi nag lock. pinindot ko din yung unlock button, di din nag function kasi hindi umilaw. nung pinindot ko ulit yung lock, i pressed the lock button 2 seconds then it locked same thing with the unlock button. di sya ng lock ng isang pindutan lang, i hhold pa yung button. tapos i started ulit the engine, nilipat ko parada ko. tapos nung i llock ko na doors ulit, pinindot ko lock sa remote ng key, ok na ulit. isang pindutan lang nag lock at unlock na sya, i tried lock and unlock 3x, ok naman na siya ulit.
may naka experience na ba sa inyo ng ganun mga paps? anu kaya naging problema sa key at hindi nag function agad to lock and unlock? imposible namang battery kasi 5 months pa lang unit ko eh.
thanks for the feed back.
April 20th, 2011 06:58 PM #2
April 20th, 2011 08:43 PM #3
April 25th, 2011 10:34 AM #4
i doubt kung hindi naisara ng maayos ang pinto. same unit po here almost 5months INNOVA G D4D. as far as i know, kapag hindi naisara nang maayos ang pinto pagkatapos you locked it using your keyless entry bubusina yung sasakyan (please correct me if i am wrong). so far hindi pa po namin nararanasan ang ganyang incident. tama po si sir marvin, your unit is still under warranty so you better let the pros check your unit.
April 25th, 2011 01:58 PM #5
interference lang yan sa open parking. try mong idikit sa balat mo yung lock before mo pindutin kung ayaw gumana you'll see the difference. Pwede rin sa chin mo idikit kapag ayaw gumana
April 26th, 2011 07:11 PM #6
April 26th, 2011 07:13 PM #7
ah masubukan nga, panung idikit sa balat yung lock sir? hehe. di ko maimagine eh. interference ba pag dinikit sa balat? akala ko kasi nun nasira ang key ko. mga ganu katagal kaya ang life span ng battery ng keys ng innova sir?
same din tayo sir, parehas tayong naka adventure din, hehe. tibay. :D
April 26th, 2011 07:15 PM #8
