Results 21 to 26 of 26
May 4th, 2011 07:42 AM #21
Thanks Sir D. Opo it still has the distributor cap and yes a month ago I replaced them all, new cap, HTW, firing pin and sparkplugs and condenser. ang hindi ko lang sinama is the ignition coil...I'm also aware na it can be many factors pa causing the symptoms but I'm looking into it na din po...I just pray na sana wala na hehehe...kinda excited na din po to use the car in long drives hehehe....salamat sir Dr. D
May 4th, 2011 10:13 AM #22
*jick.cejoco...thanks for that very technical explanation sir. As I read over the net, the 2E engine is a very mechanical engine the technology is post 70's 80's....but there is one thing I can only say about the carburator technology, it is a reliable one, I mean in terms of use and manageability.unlike the electronic ones we have today.These days components are modular in design right?repair is as easy as pulling out one whole PCB and replacing it with another even if one tiny component is the only problem...anyways thanks for the input sir. I appreciate it very much For now I'd stick to the 2e...until my pocket could afford to buy the VVTI ones hehehe
- Dec 2006
- 273
May 4th, 2011 01:41 PM #23speedibot,
remember, kahit bumili ka ng bosch, ngk or denso, sasabihin nilang original ito..ang tanong...TOTOO BA? Ang original ng spark plug ay walang butas sa tip (kung saan ikinakabit yung high tension wire). I always buy my spark plugs sa reputable dealer gaya ng casa.
eto mai-share ko sa u mga service specs ng 2E:
Valve clearance: intake & exhaust: 0.20mm (0.008 in.)
Spark plug type: Denso (W20EXR-U) ; NGK (BPR6EY)
Spark plug gap: 0.8mm (0.031 in.)
Ignition timing: 10 deg. BTDC
Engine oil capacity: 2.8L (with filter); 2.6L (withuot filter)
(Info based in corolla owner's manual)
May 5th, 2011 07:52 AM #24
*macgyver1432000 Maraming Salamat! Lalu na dun sa specs ng sparkplug....matagal ko ng nireresearch anu specs nun....kaso sa tagal na hindi ako makakita antay ko nalang yun tindahan magbigay...and yes po....halata po sa mga tindahan kahit baguhan lang ako....hindi lahat totoo at specs specified mga binibigay nila. minsan nahahalata ko para nalang makabenta sila. Am thankful there is such forum na ganito para makadagdag din sa knowledge nating consumers. BTW po yun 10 deg. BTDC is for premium gasoline? hindi po 8? kasi I use XCS...I tried unleaded pero totoong tumotope ang makina
- Dec 2006
- 273
May 5th, 2011 10:11 AM #25speedibot,
masaya ako't nai-share ko sa iyo mga info na dapat mong malaman. kaya 10 deg BTDC ang nirecommend ko, kasi, yung pinsan ko ay pareho kayong makina na 2E. Actually, sinet ko sya ng 11 deg BTDC para ma-utilize mo ang buong power ng fuel bago sya i-exhaust. Ang standard talaga sa 2E ay 8 deg BTDC, but take note...anong octane rating naman ang recommended? pls. remember na the higher the octane you use, the higher the degree you must set, pero, paisa-isang degree lang ang pag-set hanggang sa ma-reach mo yung peak power ng fuel. kaya tumotope, kasi complete combustion na yung fuel, eh di pa sumasara yung mga valves, at yung piston ay di pa nya nare-reach yung pinaka-top position nya.
so, kung stick ka lang sa XCS na 95 octane, set mo na lang sa 10 deg BTDC, but it's up to you, kung sa tingin mo tumotope, gradually magbawas ka ng paisa-isang degree. but if you notice na kulang pa sa power, vice versa lang.
May 5th, 2011 12:36 PM #26
*macgyver1432000...Thanks again. I'd stick dun sa suggestion mo sa 10 BTDC kasi the last time pinachange ko sa mechanic yun distributor, firing pin etc. tinanong nya ako anu gas gamit ko,sabi ko XCS then he adjusted nga the degrees and when I asked ano degrees nya sinet he told me nasa 10 raw. kaya its ok. Yun kasing unleaded kaya ko na share is because my boss" car is also an XL with a 2E, ang gamit nya raw ay unleaded kaya everytime pinapadrive nya ako..ayun madalas tumope...ramdam ko yun mahina hatak....
Hybrids and EV
