Results 31 to 32 of 32
- Jul 2010
- 166
April 28th, 2011 10:21 PM #31isa pa pong tanong ko, bakit po kaya pag inikot ko yung distributor ko wala man lang pagbabago sa tunog o andar ng makina, kahit iretard o advance pareho lang tunog ng makina, di ba po ba pag naka advance dapat tataas ang idle?
- Aug 2008
- 51
April 30th, 2011 12:05 AM #32wala man lang ikot ng flywheel? sounds like your problem is electrical. i'd check the ignition switch. not the part where you insert the key, but the switch at the end of the key cylinder, where electrical wires attach. sometimes the switch is replaceable, sometimes you may have to replace the entire switch assembly. another item to check is the starter solenoid. maybe it needs replacement. it's easy to check, if one knows how. check also all electrical connections.. baka loose connection.
the high tension circuit (ignition coil, distributor, high tension cables and spark plugs) and the starter circuit (starter solenoid and starter) are two different things. problems in the hi tension circuit usually do not affect the starter circuit. that means, the engine will still revolve but it will not catch life. problems in the starter circuit will usually be bypassed by push-starting the vehicle.
but if the problem is the ignition switch: 1. either the idiot lights will not light up at the second click, and the starter solenoid will not activate (no solenoid click); OR 2. idiot lights light up at the second click, but starter solenoid does not click.... some cars have another solenoid that activates the starter solenoid (may be factory spec or may be aftermarket modification).... heck! it's easier to do than to describe..
good luck.
Maraming Salamat :)
