Results 21 to 26 of 26
December 7th, 2009 12:12 PM #22
Redtop (high comp) 16V 1587cc (1.6liter) non TVIS
Compression: 10.3 w/ piston cooler
Power: 140BHP *7200rpm w/ 110lbs trq 4800rpm
Bottom Block: 7 rib reinforced aluminum
Fuel Metering: MAF (Japan) AFM (US)
Injectors: 235cc
Silvertop 20V 1587cc (1.6liter) Individual Throttle, VVT
Compression: 10.5
Power: 160BHP *7400rpm w/ 119lbs trq 5200rpm
Top Head: Non polished port
Bottom Block: aluminum
Fuel Metering: AFM
Injectors: 295cc
Blacktop 20V 1587cc (1.6liter) Individual Throttle, VVT
Compression: 11.0
Power: 165BHP *7800 w/ 119lbs trq 5200rpm
Top Head: polished port
Bottom Block: lightened aluminum, lightened crank & lightened rod
Fuel Metering: MAF
Injectors: 295cc
December 7th, 2009 02:29 PM #24
It's a 1.6. They really don't have much torque.
If you're going for it... the Silvertop and Blacktop 20Vs give you the most naturally aspirated power. The 4AGZE is also a good engine, powerful and torquey, thanks to the supercharger.
The old redtops are fun, but lack that "oomph"... 140 is a lot, but you can get nearly that much from tuning a regular 1.6... better to go all out.
My pick? 3SGE. More accessible power low-down.
- Aug 2009
- 1
December 7th, 2009 05:30 PM #25I think that depends on why do you need a more HP on your engine?
Are you into a full time racing or just weekend racer and use it as a daily driven car?
If you're a fulltime racer go with ST or BT. These engine performs well on
high revs so definitely fuel consumption will sacrifice.
If you'll be using it as an eveyday car and doesnt wanna get smoked by
Honda's in Edsa or C5 get a 4efte engine you can go head to head on these cars. What's the advantage? Fuel consumption. But important thing is safety
if you wanna race dont do it on the streets do it on the strip.
- Dec 2009
- 2
December 12th, 2009 10:30 PM #26Hhmm…actually guys, I just want my little 1.3 to be a little bit more responsive and a bit more powerful than the other 1.3’s out there nalang. Would intake and exhaust system do me justice? Besides I’ve never driven a more powerful car than a 1.3 anyway.
BDW, can a 1.1 engine outrun a 1.3? Assuming both are stocks.
Again, a big thanks to you all who participated this forum.
