Results 1 to 7 of 7
- Mar 2007
- 153
September 19th, 2009 07:48 PM #1Hi! Need help with my 98 Camry. One of my high tension wires, particularly for piston #1, is about to die any time soon. I need to change it asap. I have found a replacement set in Cruiser in Sucat for only P1k but the igniter tip would not clip or lock on to the ignition coil. The cheapest original I found was going for P3.8K but is out of my budget.
I noticed that several auto supplies sell thicker high tension wires in blue, red or yellow for only P850. I do not mind using any of these except that I cannot find any for a camry. I heard that Mallory custom makes high tension wires? Are they cheap? Where can i get them?
I am not looking for any performance or power gains, it is a plus, but my main priority is just to make my car run smooth and save on gas.
My last resort alternative would be a surplus for a toyota corona at Evangelistsa but it is not really an exact fit as the igniter tips of the corona are elbow types while the camry is straight. Can you recommend any surplus shops in Banaue or evangelista that may have them?
Could you please help me out? If you can suggest a brand, where to buy them, and contact details of the shop, I would surely appreciate it.
Hope to hear from you. Thank you in advance.
September 20th, 2009 12:58 AM #2
sir try nyo kontakin yung seller dito kung available pa, 2nd hand lang yata..
http://www.sulit.com.ph/index.php/vi...h+tension+wire
September 20th, 2009 01:28 AM #3
MALLORY, ACCEL ,SPLITFIRE, TAYLOR NGK HIGH TENSION WIRE are the best choice of sparkplug wire set . Last time i ask about the price of NGK BLUE SILICONE High tension wire cost around 5,500 pesos.
September 20th, 2009 01:50 AM #4
Besman auto supply in marulas valenzuela says to carry "all" spare parts available for toyota... even seen a customer bought a whole trunk lid(trunk door?) for a corolla taxi. which is not very common for me kapitbahay lang kase ng asawa ko yung may-ari eh. try mo na lang sir.
or settle on oem counterparts for your camry like NGK etc. just find the right replacement part.
September 20th, 2009 08:26 PM #5
Nothing beats the OEM wires unless you're running serious ignition and power upgrades. You have to change all as a set as these deteriorate more or less evenly and if you're keeping the car for a long time then get a brand new OEM set from Toyota (try checking out NGK or Toyorama in Banawe).
You can also look at the Bosch and NGK brands.
- Jun 2009
- 11
September 20th, 2009 09:17 PM #6I bought mine (original) sa Aerodynamic(s) -- forgot kung may 's' sa dulo. It's for a Corolla. Meron din silang replacement. The shop's in Manila, on Masangkay street (yata), between Recto and Soler. That's where I usually buy my car parts and so far wala akong reklamo. Although I must admit that I don't know if the high tension wire you need is similar to the high tension wire that I bought (the ones connected to the spark plugs yata, sorry di ako maalam sa kotse).
- Mar 2007
- 153
New Car Sales in 2023 by Major Brand Japan’s 223 New Car Sales Rise for First Time in Five...
Car Sales Data (2023)
