Results 1 to 7 of 7
- Apr 2011
- 35
February 4th, 2012 09:38 PM #1hello tsikot community. patulong po sana ako..
I have a 2007 2nd Gen VIOS 1.5 A/T.
pinagawa ko po yung magnetic clutch(air-con) this morning sa DENSO.
-they lifted the car on a hydraulic lift to repair the magnetic clutch.
-to properly access the magnetic clutch, they turned the wheel to the right by pulling and applying force on the tire gently hanggang max right turn na yung tire.
-there were times na para iaccess yung engine bay, binaba yung vios with the wheels at max right turn pero hindi fully baba. yung sakto lang dumikit sa ground.
-after the repair, they turn back the wheels original position by again applying force on the tire gently.
-the car was back on the ground with wheels at original position.
after leaving DENSO, I immediately notice na the car was incredibly bumpy. as in sobrang tagtag. the when full turn, parang may humps na parang may bukol yung tire pero wala naman on my inspection.
hindi ko alam kung anong problem.
car history:
100k kms
never pang na align, mejo liko na yung steering wheel.
mags are 17" then all are stock. no parts replaced.
thanks tsikot community!
February 4th, 2012 10:42 PM #2
Yung parang may humps, baka nagalaw yung cv joints mo. Yung sa tagtag naman, baka shock absorbers mo na may problem. since 100k na mileage mo at naka 17" mags kapa, busted na siguro shocks mo. Sa auto ko din naka 17", nagpalit na ko ng rear shocks sa 60k mileage pa lang. Ipa check mo na lang suspension mo.
- Apr 2011
- 35
February 4th, 2012 11:12 PM #3my shocks were fine before the aircon repair. kaya nagtataka talaga ako kasi paglabas parang i'm on a totally different car. yes yung mga full turn may parang humps talaga. minsan naeexperience ko rin sya pag mejo kurba yung daan.
- Aug 2005
- 183
February 5th, 2012 04:05 AM #4Nung nilift yung kotse nag full extension yung shocks. Pag baba tumukod na yung shocks. Stuck up siguro. Happened to my crv, nagpachange oil lang ako. They used lifter tapos after ng change oil paguwi ko super tagtag, had it checked sabi na tumukod yung shocks. Lalo na sa yo 100 k mileage. Most probable yung stuck up shocks.
February 5th, 2012 09:46 AM #5
Yung sakin naman, nakita sira na shocks sa rear/left side nung nagpapalit ako ng lowering springs. Kaya pala bouncy na masyado ung ride ko nuon. nung una kala ko lang matagtag kasi naka 17" na rims. Most likely ung parang may humps sa CV joint mo na nga yun. Ganun din sa dati auto namin, may tunog pag kumakabig lang.
- Apr 2011
- 35
February 5th, 2012 11:13 AM #6thanks for the reply mga sirs. ako din hinala ko shocks pero nagtaka ko nilift lang tapos ganun agad. so nangyayari pala ganun. tried it today. the rear shocks plays well pag inaalog yung trunk. yung front right shocks mukhang me mali. dun side sila gumawa.
so is it possible din pala yung full turn to the left ko yun yung may parang humps, so if nag full turn to the left, yung car naglelean sa right side ng car, kung busted nga yung front right shocks ko di kaya nakaencounter lang ng road imperfection yun then yun yung nagcause ng humps effect since di madampen ng shocks yun bounce?
February 5th, 2012 10:20 PM #7
Pwede nga yun sir kasi kahit small road bumps lang magiging matalbog na yung sasakyan. Ang cause nito ung spring na lang nag support sa suspension at ala na damping kaya bouncy.
