Results 1 to 7 of 7
July 5th, 2012 05:42 PM #1
Mga gurus it all started when we took the rolla for a long drive to dingalan aurora when we went back home the next day i noticed that may lumalabas na white smoke pag mainit na ang makina and masakit sa mata ang usok no overheat whatsoever yung smoke lang talaga and it is very annoying ano kaya ang poss causes nito ayoko na ngang dalhin sa work at parang tricycle na 2 stroke eh thanks in advance
July 5th, 2012 07:00 PM #2
could be a head gasket leak wherein coolant or water is being burned.
pag itim, ang alam ko oil.
July 5th, 2012 07:06 PM #3
pag nag start sya at hindi pa umiikot ang mga aux fan nya parang may hangin na sumisingaw sa may cylinder head not sure kung cylinder head nga or sa manifold gasket thanks for the reply bro
- May 2008
- 117
July 5th, 2012 11:59 PM #4check the vacuum hoses. baka may sumisingaw at nagrich ang fuel mixture kaya puti na usok at mahapdi sa mata.
July 6th, 2012 12:09 AM #5
pag kaka alam ko pag rich ang fuel black ang makikita sa tambutso
pag blue sa tambutso langis na nasusunog sa loob ng combustion nagbabawas ang langis (dipstick)
pag white condensation sa exhaust or coolant nasusunog sa loob ng combustion
- Jun 2011
- 134
July 6th, 2012 11:49 AM #6Try to check the PCV valve located sha sa valve cover.Bka dun din nang gagaling ung sound sa parang sumisingaw.Pwede din sa valve seals.
July 11th, 2012 12:12 AM #7
ok na mga bro pinalitan ko ng spark plugs kanina bago pumunta ng makati nawala ang usok thanks for all your advises mga tol
Thank you!
