Results 1 to 7 of 7
- Feb 2014
- 4
February 26th, 2014 12:07 AM #1Hi Guys,
I have a 2004 1.5G A/T Vios. Its mileage is around 91K already; could you guys inform me as to what parts I should replace and have checked? I previously considered buying a Wigo but then realized that maintaining this would be the better alternative. If you could help me with improving fuel consumption, it would also be greatly appreciated.
- 52,731
February 26th, 2014 12:26 AM #2i believe the casa has a schedule of parts checking, adjusting, and/or replacement. the information is free for the asking.
you can also consult the owner's manual. they print maintenance schedules in there.
and except for timing belts and oil, i'm not a very good example of preventive maintenance.
February 26th, 2014 09:25 AM #3
+ 1 on consulting the owner's manual, most are really stated there. It's really following the proper PMS schedule (keeping your car in top condition) and then some (i.e. checking tyre pressure regularly, planning trips). Matipid na ang Vios 1.5L right? If you want something more efficient then you have to get a newer mini car i'd guess.
February 26th, 2014 01:51 PM #4
February 26th, 2014 01:58 PM #5
February 26th, 2014 02:05 PM #6
And its good practice to let the ole lady rip it on the highway for awhile. If just to loosen all that carbon gunk inside the engine.
February 26th, 2014 04:37 PM #7
Check your shocks and aux fan at this time and various belts. CV joints, ball joints, tie rod and some bushings among others.
On the fuel consumption side, for sure, replacing the fuel/air filter, plus oil and filter change would help. Engine decarbonizing too. Brand new spark plugs would improve your FC as well. I suggest have your ATF checked and if it needs replacing, do the dialysis type ATF change. It's so much better. Change your tires to a 'low-rolling resistance' type. Bridgestone Ecopia, Goodyear Assurance (? i think), Kumho Solus KH17 are good low rolling resistance tires. Like you, I'd rather drive an older tip-top cond Vios 1.5L than a brand new Wigo.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
