Results 41 to 50 of 101
- Apr 2009
- 429
April 11th, 2018 02:58 PM #41If you had your battery checked and turned out its still got enough juice, its probably worth a try that you bring your car to a competent shop. Dismantle your door trim panels,clean the electrical connections of your door actuator (with electronic contact cleaner), check their electrical integrity (resistance, contact, etc) then put them back but seal the connections with dielectric grease. Check also the electrical connections of your of your central lock switch. Sometimes, electrical motors that are rarely used are the ones that will have problems like corroded contact points and seized up armatures, especially so we are in a humid environment. Just curious too if your garage is always moist? If after doing this remedy and your actuator still doesn't work, you have no choice but to replace them
May 5th, 2018 01:52 AM #42
That's what my good friend told me also. He said I can bring it sa Ginza in Banawe. That's where I used to go for my car stereo e. But my issue is if it's broken, where to get the parts
If I replace the actuator that is PER DOOR? or that is a set. I don't wanna spend 10k for door locks
And BTW my other Corolla is having locking problems too. The universe is playing tricks on me. What are the odds???
- 52,731
May 5th, 2018 01:55 AM #43in the old altis, the actuator is a small electric motor.
in the new altis, i am not sure if it still is an electric motor, or a solenoid.
at any rate, the banawe guys should be able to say, without opening your door yet, if spare parts (brand new or surplus) are available.
while casas may sell by assembly, banawe will sell by piece, if such is available.
but if you are supremely lucky, all that will happen is that they will find a small piece has detached from its position, and that putting it back in the correct position, solves your problems.
punta na, madam.you are only prolonging your agony.
good luck.Last edited by dr. d; May 5th, 2018 at 01:58 AM.
May 5th, 2018 02:08 AM #44
But where in Banawe do I go? Are the shops usually open on a Sunday? It's traffic hell for me to travel there on a weekday
- 52,731
May 5th, 2018 02:11 AM #45some stores are closed on sundays and holidays. so if they happen to be the only ones holding the parts in question....
better to go early saturday. 8 am, to be reasonably assured of a parking space. "huwag magpa-gawa sa walang paradahan." we don't know how long we're going to stay.
ask your suking stereo store, for a recommendation. they know each other there.
i do not want to recommend the nearer evangelista. "walang paradahan", among other things.Last edited by dr. d; May 5th, 2018 at 02:20 AM.
May 5th, 2018 02:25 AM #46
May 5th, 2018 02:28 AM #47
- 52,731
May 5th, 2018 02:29 AM #48
May 5th, 2018 02:40 AM #49
- 52,731
May 5th, 2018 02:47 AM #50
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
