Results 1 to 6 of 6
- Sep 2008
- 142
October 29th, 2011 11:27 PM #1i need help on my 2005 prado local AT. bigla lng po umiilaw yung ABS light sa my dashboard pag malayo na natakbo nung car, pag minsan d naman po umiilaw. mag off lng ilaw pag pinatay na makina. pls help me, what might be the reason?
- Jul 2009
- 57
October 29th, 2011 11:33 PM #2The culprit is usually your abs module. Sometimes it is as simple as a severed wiring to as morbid as replacing the module
itself.
- Sep 2008
- 142
October 30th, 2011 07:05 AM #3oh! i had it analyzed thru computer in one of the shops here, eh wala naman po makita, it is just the recording of the ABS popping out from the dashboard. d naman daw po delikado kahit naka ilaw daw po, though im not that comfortable driving with the lights on.
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 30th, 2011 09:09 AM #4Have your brakes and abs sensors cleaned. Sometimes if dirt get in the abs sensor it makes the dash bulb light up. Hopefully cleaning will solve your problem. While your at it, might as well change your brake fluid if you have not done it before.
- Sep 2008
- 142
- Sep 2008
- 142
February 23rd, 2012 08:34 PM #6cleaning lng po pala nung mga sensors ang kailangan, since nung nalinisan nawala na po yung umiilaw kaya i'm enjoying this car until this time.
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
