Results 1 to 10 of 11
- Jul 2010
- 166
October 19th, 2011 02:43 PM #1ask ko lang po kung okay na po ba ang QUALITY nung grounding kit na nasa 800 to 1000pesos na presyo? gusto ko po kasi magpalagay ng grounding kit, 18years na po kasi edad ng auto ko kya panahon na siguro para maglagay ng grounding kit.
October 19th, 2011 10:40 PM #2
yup, ok yan. lalo nang matanda na oto natin.
kung mahilig ka mag DIY, mas mura pa nga kung ikaw ang gagawa nang grounding kit mo.
balak ko din bumili ng grounding kit na HKS, kaso mahal dito samin nasa 1,500 petot. eh sa banawe nasa 800 lang nga.
plano ko nalang gumawa ako nang sarili kong kit.
- Jul 2010
- 166
October 20th, 2011 07:44 AM #3maraming salamat po sa reply, paano po ba mag grounding? san po ba dapat ikakabit yung mga wires? carburetor pa po yung auto, 2e engine.
October 20th, 2011 12:38 PM #4
yung sa norkis legacy ko ako lang gumawa ng groundings nun, DIY grounding kit ika nga,
there are two patterns where you can bolt on your DIY grounding kit:
Diagram 1:
here's another way, Diagram 2:
yung akin, diagram 2 ginamit ko medyo nahirapan lang ako mag-bolt on sa alternator (kasi nasa bottom part, sa likod ng engine yung alternator ng auto ko at masikip pa yung engine bay niya), and yes you can notice the differences like,
-Brighter Headlights
-Quick Starting
-Smoother and better A/T shifting response
-Idling goes stable and fine (ang kinis ng menor)/engine ran smoother
-Improves sound quality of my stereo and speaker unit, medyo lumakas ang output ng speaker.
heto naman yung mga ginamit ko:
- 4 meters of 8awg wire (i make it for meters, para may allowance, pero sobra pa yan, on my case I just consumed 2.5 meters)
-eyelet terminal (bale 12 - 15 pcs. para hindi kulangin)
-allen screws and nuts
-tie wires/zip wire
tools I used:
-pliers
-cutter
-wire stripper (o kung wala pwede swissknife)
-wrench
it just cost me less 300php, wire just cost 30 - 45 petot/meter, yung mga eyelet terminal 5 petot/piece, yung screw and nut mga 50php ata bili ko dun sa hardware na malapit sa min noon.
kung magpapa-install ka naman sa mga shop, like sa mazda ng ate ko, she spent 800 for the grounding kit and 350 for the labor/installation, total of 1150php at banawe Q.C, way back 2008. halos parehas lang din naman, parang mas maganda pa ang DIY e kasi mura at naka-enjoy gawin. ang kagandahan naman ng mga nag-iinstall sa shop, malinis, nakatago yung mga wire, you can't notice kung saan pinadaan/pinagapang yung mga wire. but again depende parin sa mag-iinstall yan, kasi yung sa friend ko madumi yung pagkaka-install ng grounding kit niya from a certain auto shop in manila, mas malinis pa yung akin kahit DIY lang.
- Jun 2011
- 29
October 21st, 2011 07:11 PM #6
October 21st, 2011 11:27 PM #7
I'll try to post my pictures.
yun akin kasi iniscrew/isinama o inipit ko dun sa hinigipitan/pinagaadjustan screw ng alternator, or pwede rin ganito- directly dun sa mga screw ng alternator(basta mag touch sa alternator) basta wag lang dun sa mga main terminal or connectio ng alternator
but on this example yung alternator naka-ground pa rin sa body,
this is just applicable for gasoline engine only, AFAIK, iba naman ang grounding diagram for diesel, but I try to look for that
- May 2018
- 2
May 12th, 2018 01:44 PM #8
May 14th, 2018 10:27 AM #9
- Jul 2013
- 2,450
May 14th, 2018 10:46 AM #10
Daming issue ng SU7:grin:
Xiaomi E-Car
