Results 21 to 27 of 27
- Dec 2009
- 242
February 18th, 2010 01:55 PM #22Just to give you update guys.
Okay na. Nilinis lang yung cable by spraying WD-40 (? not sure actually). Dinala ko sa auto shop, ganun lang ginawa then ok na. For free! :D
But if kung bumalik daw yung problem papalitan na yung cable. Buti na lng umayos na.
- Mar 2009
- 25
February 21st, 2010 12:11 AM #23hehe sabi sayo pwedeng i-DIY lang eh. linisin mo na din yung paligid ng piagkakabitan ng accelerator cable.
- Dec 2009
- 242
February 26th, 2010 10:15 AM #24Thanks sideskirt. Sana matutunan ko din soon mag-DIY. Takot pa ako kasi ngayon pa lang ako nagka-sasakyan.
February 27th, 2010 12:02 PM #25
- Mar 2009
- 25
March 12th, 2010 03:15 PM #26brother mas delikado ang biglang brake lalo at naka neutral ang gear mo. galing ka ng 5th gear * 100kph biglang brake, mag skid ka nito at lalong semplang ang aabutin mo.
ang proper ay unti-unti mong ibaba ang gear until makarating ka ng 1st gear saka ka mag alalay lang sa preno last resort ang handbrake. same thing kapag nawawalan ng preno ang dapat gawin.
* sir samcoy ayos yan matutunan mo din po mag kutingting ganyan din ako nung nag start pa lang din, tapos kinareer ko nung na ondoy ang oto ko.
- Apr 2009
- 33
March 12th, 2010 07:32 PM #27Pareng SIdeskirt,
ang sabi po ni ARBE put to neutral, then brake, wala po syang sinabi na brake suddenly...;)
I believe ARBE is right, if your engine is reving nag your gas pedal is stuck, just shift to neutral, then pull over and check. I dont think it is right na unti-unti mo i down shift, when your brakes are perfectly working lang naman...
Then you gas is stuck at high rev, the first action is to get to the safe sife of the road and pull over. If your brakes also dont work, use your hand brake, if your hand brake dont work, turn off you engine, and use your engine as brake. This can be done, using your dead engine, put in gear and slowly depress clutch, on right gear for that speed, then pull over and quickly as soon as safely as possible.
But to avoid all this, Please maintain your baby's regularly. Your life depends on them..
BEst Regards,
BEN OC plus Racing
Traffic!
