Results 1 to 10 of 42
- Apr 2007
- 1
June 22nd, 2007 09:01 PM #1how do we improve or soften the ride of the toyota f4x4 fortuner? whats the best way?
June 22nd, 2007 09:15 PM #2
short term solution and probably the cheapest way is to decrease the recommended tire pressure by around 4 to 5 lbs/sq in. however, you might have to sacrifice the life span of your tire...
maybe the best method is to replace the existing shocks, i know some people who were pretty satisfied with the ride right after changing the shocks
June 22nd, 2007 09:30 PM #3
you may also try to visit and learn from the fortuner owners on this site.
http://pinoyfortuner.14.forumer.com/index.php
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 23rd, 2007 01:40 AM #4I wouldn't lower the tire pressure THAT much. Delikado din kasi sa blow-out eh dahil baka me-deform ang belts. There are ads for aftermarket springs but I haven't tried them myself.
Seriously though. Ride comfort is one of the things that should be tested in the test drive.
Doon sa hindi pa nakaka-try, kung gusto niyo talaga nice ride, try the FXT. Grabe. Palagay ko next down will be the SF.
June 23rd, 2007 10:13 AM #6
use nitrogen on your tires, get an aftermarket set of springs and shocks.
June 23rd, 2007 02:52 PM #7
try speedlab spring and shocks combo
bilstein shocks
H&R springs
here's the link:
http://www.speedlab.com.ph/installat...ilsteinh&r.htm
- Jul 2005
- 95
June 24th, 2007 04:11 PM #8The Fortuner's ride isn't that bad naman, I guess it's because my previous ride was a pick-up truck. Lowering the tire pressure will help in softening up the ride, but handling and fuel economy will be affected. I heard from another owner that he will be changing the springs and shocks soon. I for one will make do with the existing set-up, doesn't make that much sense changing brand new stuff if you can't trade them in or sell them.
June 24th, 2007 04:34 PM #9
June 24th, 2007 05:02 PM #10
As I've said previously, it's actually not bad in front... but if you ride in the second or third row out on provincial highways, it can be very jarring. I'd rate the front as being about Ranger-level in comfort, and the rear as being Frontier-level...
