Results 1 to 10 of 18
October 16th, 2006 10:08 AM #1
Hi guys:
Need a little assistance with regards to the topic. My boss recently purchased a fortuner for his son and being a sedan guy all his life, doesnt know how to operate the 4wd system.
I only know the basics of 4wd:
2h - ordinary driving (paved roads)
4h - slippery roads (gearing of 2h on 4wd)
and 4L - for the ultra crawling action
However, my boss mentioned the presence of a difflock. Immediately I thoght of rear locking diffs similar to the Safaris. Then a tsikoteer mentioned that center locks are the ones present since its an awd nga pala in default driving.
I knew that the center difflocks work this way:
awd - center locks are not engaged to be able to operate in paved roads
4h - engaged locks
4l - engaged locks
Tama ba pagkakaintindi ko? By the way, is there a separate button for the center lockers or is it automatic when you put the vehicle in 4h and 4l?
TIA guys!!!
October 16th, 2006 10:10 AM #2
4H - All Wheel Drive Mode (for road use)
4Hlc - 4 Wheel Drive with C/D locked (off-road use), same as 4H of pick up trucks
4LlC - 4 Wheel Drive with C/D locked and in low range (off-road use)
Center diff will lock itself when you shift into 4Hlc and 4Llc.
October 16th, 2006 12:29 PM #4
Also, check under the driver windshield visor. There's an instruction card there on when and how to use the diff-lock. Better yet, ask them to read the owner's manual...
October 16th, 2006 12:46 PM #5
Vicoyski,
Thanks. Hehe. Medyo naguluhan daw siya sa manual kaya nagpaturo. Anyway, I think I was able to relay the instructions to him correctly naman.
Otep,
Thanks for the help. Sorry for the impromptu call, nakaistorbo pako. Salamat ulit.
October 16th, 2006 05:50 PM #6
October 16th, 2006 05:58 PM #7
Lahat ba ng versions ng Fortuner ganito? May nakita kasi ako di makaakyat sa parking ramp dahil basa. Lahat ng power pumupunta sa left rear wheel na dumudulas.
October 16th, 2006 06:33 PM #8
Only the 3.0 G variant is AWD.
Dapat talagang basahin ng owner yung manual... it's very bad to run the vehicle in locked differential mode on pavement... and it's very expensive to repair if anything happens to the drivetrain because of that.
October 16th, 2006 07:09 PM #9
October 16th, 2006 08:19 PM #10
OT:
Ang masakit nito, pagkatapos bumili ng Fortuner na 4x4, and then later on realized na hindi pala niya kailangan ng 4x4. I think there are lots of car owner out there that bought 4x4 rig that haven't tried using its 4x4 system.
Parang maintenance ng Master Garage ito? Sent from my 2107113SG using Tsikot Forums mobile app
