Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Mar 2004
    yung vios po ulet, amoy gas yung oil sa dipstik bakit po kaya?
    don't be too paranoid bro. check mo muna underlying symptoms like may usok ba na white sa muffler? may leaks ba? otherwise, leave it all out and ignore it. baka di mo na makatulugan yan, mahirap na.
    smell something else
    Mar 2004
    ahaha tenkyu sir... di bale papa change oil naman na yun ehehhe... due na rin.. natanung ko lang hehheehe
    Jan 2008
    Gas engines normally have its Oil smells like GAS or sometimes burnt gas basically because it is burning gasoline in its combustion chamber, some of this combustion gasses escape past the piston rings (blowby gas). These blowby gas can leave soot inside the engine and as the oil main function is to clean the engine these soot will mix with the engine oil and therefore will smell like gas
    Oct 2008
    kuya yapoy pasingit naman po
    yun sakin kasi meron din white smoke amoy gas madalas po sya pag start ng engine sa umaga pero pag mainit na po makina nasa kalahati na nawawala po pero amoy gas pa din yun usok
    wala nman pong oil sa dulo ng tambutso or itim na usok talagang white smoke lang po
    pag ganun po ba may tama na piston ring ko or valve ? or tune up lng ? ano po ba gagawin ko kuya?
    Jan 2008
    AFAIK, most gas engines will emit white smoke during cold start especially in the morning due to condensation of its exhaust gasses left inside the exhaust system...sometimes you will also see water mist coming out of your tailpipe..
    is your engine carb or EFI?? if carb, possible you need a tune up and adjustment of your AIR-FUEL ratio and engine timing, if EFI, tune-up may help, have your engine in proper timing, and inspect vacuum hoses for leaks...
    I have one time experience with my Suzuki Every F6A EFI engine.. i noticed medyo maaamoy gas yung exhaust and tumaas ang FC only to find out meron pala isang vacuum hose na disconnect... replacing the vacuum hoses solved the problem
    Oct 2008
    tnx kuya YAPOY sa reply nyo po
    carb type pa po yun corona ko sabi ng toyota dasma semi efi daw yan kasi my elec di yan ordinary carb daw papa chek ko na kaso sobrang haba pila nasa pang 21 nako
    saka na chek nila wala naman daw oil / resudue sa tip dulo ng nun tambutso saka di nausok sa deepstik ba yun kaya di pa daw pa overhaul yan chinek lang sa parking
    ayaw ko naman pagalaw sa mga kanto mechaniko sabi kasi ng mechanic ng toyota dasma mahirap galawin yan ganyan carb daming hose at elec ginamitan pa daw yan ng manual nakita ko nga mukha nga mahirap galawin
    kuya yapoy san po ba kayu nag papa service yun trusted machanic mo? baka mapadaan po ako try ko po. taga cavite lang po ako
    tnx again kuya yapoy
    Apr 2013
    gud am p0 kuya ung akin ksi suzuki efi f6a pag n trafic aku bgla n lng nwwalan nng htak kht tpkan ung gas nwwla lng sya bkit kya gnun kuya nlinis ku n din ksi ung efi tnx p0
    Quote Originally Posted by tracyangel View Post
    Bawal po text speak sa tsikot. Kumpleto naman po siguro keyboard ng laptop/desktop/smartphone natin.
Engine oil smells like gas
