Results 11 to 17 of 17
November 20th, 2003 05:17 PM #12Originally posted by Ungas
Magkaiba po sila, the Tamaraw FX uses the 2C engine (2.0L) while the Revo is using the 2L engine (2.4L) which is also the same with Hilux pick-ups.
3L yung sa hi lux 4x4, 2.8L
November 20th, 2003 08:29 PM #13
Yung mga naunang hilux pickup 2L engine nalimutan ko model LN105 yata yun (solid diffs front and rear). Yung bagong modelo IFS hilux models have 3L.
I think 2L engines have 75 hp output, di ko na maalala yung engine specs.
November 20th, 2003 08:56 PM #14
Eto po pala may nakita akong specs ng 2L engine:
Fuel Type: Diesel
Engine Model: 2L
Engine Design: 4-cylinder In-line, 8-valve, OHC Belt Drive.
Displacement (cc.): 2,446
Bore and Stroke (mm.): 92.0 x 92.0
Compression ratio: 22.2:1
Fuel Supply System Distribution type: Fuel Injection
Max. Output (PS/rpm.): 75 / 4,200
(kW/rpm.): 54 / 4,200
Max. Torque (Kg-m/rpm.): 15.4/2,400
(Nm/rpm.): 151/2.400
November 21st, 2003 03:33 AM #15Originally posted by Ungas
Congrats on your new ride! :D Binyagan na yan! Dalhin sa Tanay para mahasa sa offroad...
Yeap Bibinyagan kaagad Test Drive puro akyatan >>> on Dec. 19th our route starts from Isabela enroute to Laoag via Aparri (8-9 hours drive) then on Dec. 21st from Laoag to Baguio taking Naguilian Road, then on Dec. 23rd from Baguio to Manaoag/Bonuan Blue Beach or San Fabian/Dagupan to meet Pangasinense Tsikoteer Chapters/ then on Dec. 26th from Pangasinan to Isabela taking Carmen >Nueva Ecija Route...
For the following Pangasinense Tsikoteers Agagi(kapatid) kita-kits tayo Dude... CSI Mall pwede rin doon...
1. Reuben a.k.a. Supierreman
2. Rod Carolino from Dagupan
3. Kinyo from San Carlos (turuan mo ko ng 5.1 Sound Set up mo)
4. Aquirius
5. Ronald a.k.a. Chieffy
6. Rapeez
7. Alsawagh
Am hoping that somehow i could meet some Genuine Ilocano Tsikoteers Kabsat ken kabagis (kapatid)
1. Jedi from Dingra Ilocos Norte
2. Kennon Road from Laoag City Sulsona Ilocos Norte
3. Cardo from Baguio
4. 20vanda01 from Piddig Ilocos Norte
5. Rsnald from Bacarra Ilocos Norte
6. 48IDA from Baguio
7. Sarangusong from Nueva Vizcaya
8. ch0k0y from Naguilian La Union
sana naman pm me your CP # contacts dadaanan ko lahat kayo on my one man trail... mini EB po tayo ...
hmm, 1 day lang po me sa Manila, i might drop by to Chieffy and buy a Shirt txt na lang kita Sir Chieffy on Dec. 05th
:hippie:
November 21st, 2003 11:11 AM #16Originally posted by Ungas
Fuel Type: Diesel
Engine Model: 2L
Saan nyo nakuha ang specs na yan?
Eto kasi ang nakuha ko sa toyota.com.ph:
The 4x2 are no ponys either with a 2.5 liter diesel engine with more than enough power.
Maximum Output: 83Hp/4,200rpm
Maximum Torque: 162Nm/2,400rpm
Sa Revo ay 86HP pa nga.
Malaki ba ang difference ng PS sa HP?
November 21st, 2003 03:55 PM #17
I just clipped it from a Toyota website. Can't remember where or what it was from. :D
Here is the formula for HP, you can do the computations with the information gathered.
HP = (TORQUE x RPM) / 5252
English HP X 0.7457 = KW
KW X 1.341 = English HP
Metric HP (PS) X 0.7355 = KW
KW X 1.3596 = Metric HP (PS)
kg/m X 7.23 = ft/lb
ft/lb X 0.13831 = kg/m
kg/m X 9.807 = Nm
Nm X 0.10196 = kg/m
kg/hp X 474.28 = hp/ton
KM/h X 0.62137 = MPH
MPH X 1.6093 = KM/h
kg/mm X 55 = pounds/inch
pounds/in / 55 = kg/mm
HTH
Automatic po Sir
