Results 1 to 6 of 6
- Sep 2008
- 54
February 4th, 2010 01:51 PM #1guy help nman.. super nahihirapan n me s prob ko. pinaoverhaul ko n un corolla ko. palit piston ring, oil ring. alternator belt, aircon belt, boots, valve seal, transmision oil seal, change oil. tapos machine shop ko un valve ko asinta barbula nga at reface. pero d problem is may usok prin kmi nakukuha from d exhaust at may white smoke s spark plug when we open c camshaft. di rin ganun ka pino ang idle ng kotse at palyado.. so ang ginawa nmin is pina asinta barbula ulit nmin dahil sabi ng mekaniko is may singaw daw s barbula.. when we got to machine shop ang sabi ok nman daw ang asinta malaman ang problem na is yun computer box. tapos ang sobrang lakas sa gasolina. help me pls. nalilito na ako. laki na ng gastos ko guys. my ride is corolla gl 90model. thx
- Jan 2010
- 283
February 4th, 2010 02:14 PM #2what engine do you have? 3EE, 3EC, 4AFE, 4AGE, 4AGTE? how's the PCV valve? the exhaust system takes time to clear up if it had residue from the last engine problem if any. is the cooling system losing antifreeze/coolant? does the exhaust gases smell unpleasantly sweet? is the radiator bubbling when the engine is running?
February 4th, 2010 04:22 PM #3
Natural lang na pag may singaw barbula ay papalya ang makina ibig sabihin loss compression kung may singaw. Iyong spark plug mo ba basa ng langis. Kasi kung maayos ang pagkakaoverhaul at machine shop ng sasakyan mo dapat hindi mausok ibig sabihin kaya mausok dahil may halong langis ang sinusunog nito . Opinion ko lang ito sa mga binagit mong dahilan ng problema ng sasakyan mo.
- Sep 2008
- 54
February 5th, 2010 01:30 AM #4mga bossing tama ang hinala nyo at hinala namin ng mekaniko ko.. nang ibalik namin sa machine ang sabi is computer box na raw ang problem.. pero pina relapping ulit namin at binantayan ng uncle ko(my mechanic), pag uwi namin kabit agad, ayun wla ng problem. wala ng smoke at pino na ang makina.. palpak ang pagkakamachine shop sa vavle ko.. buti nalang binantayan na namin the 2nd time around kaya natutukan ng maayos. ok na po ang rolla ko. salamat po. dapat talaga walang kasingaw singaw ang barbula parang masarap ihataw ang ae92. thx
February 6th, 2010 10:30 AM #5
[SIZE="4"]Reminder: do not post in SMS/TXT format.
Read the RULES.[/SIZE]
- Feb 2010
- 1
February 23rd, 2010 09:48 AM #6Mga Sir,
Bago lang po ako dito, May prolem din po ako sa Toyota corolla 95 Xl ko. May usok po sya pag tumatakbo na pansin ko lang na blue yung smoke sa tambutso, Ano po ba kaya ang posibleng problema, sabi po kase ng mekaniko, valve seal daw po at top overhaul. Para din po bang nag pa overhaul ako ng makina dati nag overheat sya kaya kumatok ang makina. For the meantime gamit mo na ako daw ako pertua o purtua sabi ng mekaniko. Help naman po kung ano pwedeng gawin?
Salamat po ng marami.
