Results 1 to 8 of 8
- Mar 2011
- 42
December 26th, 2011 11:31 AM #1Hello mga Sirs,
may tanong lang po ako tungkol sa aking corolla bigbody ung brake ko po sa likod hand brake bakit kaya ganon kapag nagkapark ako sa patag okay naman kumakagat siya pero kapag sinubukan kong magpark na naka incline ung hand brake ko parang dumudulas so tendency maglalalgay ako nang kalso para di siya dumulas.
ano kaya possible na solusyon dun linisan lang ba? or may kailangan na palitan.
Salamat po
December 26th, 2011 11:35 AM #2
It may just need adjustment or the e-brake cable may be too stretched already. How many clicks does your e-brake need to engage?
- Mar 2011
- 42
December 26th, 2011 09:30 PM #4
Check mo din sir kung may adjustment doon mismo sa handbrake kinakabitan ng cable baka magbago pa yung clearance ng handbreak
- Dec 2006
- 273
February 2nd, 2012 07:03 PM #6There are things you're going to do:
1. Check if your brake shoes are manipis na....
2. If your brake shoes are thick enough, try to clean them by using sandpaper, and try to clean the drum as well...
3. there are points of adjustments for the hand brake cable...first..nasa ilalim sya ng kotse..second..nasa brake assembly sya..may kinakalabit/iniikot dun by using flat screw driver..adjust na paluwag ang "buka" ng brake shoes..pero wag namang too tight, baka di mo na maipasok yung drum...try mo lang...
- Mar 2011
- 42
February 5th, 2012 09:42 PM #7Mga Sir,
Pasyensya na po newbie lang po ako pano po iaadjust saan banda yang brake assembly
plano ko po na linisin ung brake drum kasi aaralin ko muna kung pano tangalin hehehe
February 6th, 2012 07:46 PM #8
Yung pag adjust ng brake, meron kang pipihitin sa likod break drum, may takip na rubber yun pag tinanggal mo makikita mo yung parang corona iadjust mo muna ng sagad na hindi mo na maikot yung drum manually saka mo irelease konte konte hangang sa maikot mo, pakiramdaman mo tama lang yung lapat ng break shoe sa drum
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
