Results 11 to 13 of 13
October 23rd, 2009 07:41 PM #11
Thats the problem... yung IC chip na yan... yan yung pinaka CPU (Central Processing Unit) The Main Brain ng ECU board mo.
It cannot be repaired once it has been damaged, since it is basically a disposable item.
Of course madaling gawin ang power supply - caps and diodes lang ito basically... it's a rectifier and smoother circuit by design. But making the board alive will not guarantee you that it will be back to normal again.
Ang analogy diyan... naaksidente yung patiente... sumalpok yung motor niya sa bus... buti na lang may helmet... kaso medyo unconscious at maraming dugo ang nawala - may sugat sa ulo...
Nilagay sa ICU... nilagyan ng Pace Maker para magtuloy lang ang pag tibok ng puso at pag hinga... so para maka survive... at mabuhay, ginawan ng paraan o remedyo.
Kaso... nung nabuhay na siya... at naghilom na ang mga sugat... gulay na pala. No more brain activity anymore. So - spiritually - in essence - parang patay na rin.
The same with your ECU.
The flood is the worst thing that can happen to it. Of course... magagawan ng paraan din yan para mapaandar ang oto mo... pero, dont count on it for longetivity or reliability.
Ika nga ni Confusious, 'Haste makes waste'... Sa hangad na makatipid... lalong napalaki ang gastos. Sa paghangad ng isang salop, isang bugkos ang nabuhos.
These words of wisdom are based on experiences of people before our time and they still are applicable today.
I am not throwing water over your determination to have it repaired...
Electronics items are super sensitive things... it's sensitive to static and with our moisted finger tips - it can already be destroyed... lalo na kung flood water which can serve as a conductor which can easily short any circuitry. Some electronic components retain capacitive charges where if shorted will give high votage surges that can zap the least resistant of everything near it. This is what happens to your ECU in a flooded situation.
I hope this also adds light.Last edited by ehnriko; October 23rd, 2009 at 07:47 PM. Reason: spelling
October 23rd, 2009 08:24 PM #12
Ingat lang doon sa magpaparepair the ECU sa Banawe iyong mga nasa labas na walang puwesto at marami na nakapagsabi na may warranty ibalik lang sa kanila at mahal ang singil nila . Iyong kakilala ko nagpagawa at ng ibalik niya dahil nagloloko rin wala na sa pwesto iyong gumawa sa kanya. Kaya doble gastos nangyari sa kanya.
December 12th, 2009 08:34 PM #13
First run of "Storm Ondoy" devastated Mitsu Montero '94 6G72 running and idling smoothly with the latest Alpha_303q burned into my self built MS2 daughtercard and Custom Designed PCB routed Megasquirt with provisions for Peter Florance's sequential injections!!! idling stepper motor is totally busted modified it to used a printer stepper and it worked and way better than that of the stock Stepper!!! Can't find a replacement for the busted Distributor so Modified the Dizzy to used a fiber-optic tru-hole sensor and it worked perfectly!!
[ame="http://www.youtube.com/watch?v=q10_m1O2jj0"]YouTube- MONTERO.3gp[/ame]
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
