Results 11 to 20 of 25
September 20th, 2007 05:37 AM #11
duda ako sa condition ng radiator mo pards. sakaling palpak yang radiator mo, overheat ka ng overheat at makakasama sa makina.. add to that iyong abala na ipapatulak or tow mo kapag nasiraan plus syempre gastos sa repair.
September 20th, 2007 08:49 AM #12
IMO, it's hard to base it on pictures... bring the car to a gas station with a mechanic and also do a good look under the car.
On the 90K price... tawad pa yan.
- Sep 2007
- 8
September 21st, 2007 08:24 AM #13thanks to all you guys!
'been learning a lot from here now...
will keep eveyone out here posted.
muchas gracias!!!
September 21st, 2007 12:32 PM #14
BTW, try to go around and look at 2nd hand cars from the classifieds (i.e. Manila Bulletin on Sundays). Widen your options. To give an example, there's a similar 1.3L Corolla up for sale on Nissanbayan for 90K as well and although it's a 1.3, it looks to be in better condition.
- May 2007
- 133
September 21st, 2007 04:16 PM #15i agree, kung matipid tlga gusto mo, 1.3 engine ka na lang, also pwede ka dagdag ng konti budget para at least model '93 - '96 na mabili mo, mga P140k -max makakakuha ka na,
kung ganyan edad ng oto target mo, go for TOYOTA na lang
- matibay
- mura at madaming pyesa
- maraming mekaniko ang marunong sa toyota
September 21st, 2007 04:28 PM #16
September 21st, 2007 07:45 PM #17
Naoverhaul na? Get the receipts and the contact number nung nagoverhaul para investigate it muna before buying it. Also I suggest that you check the car from a cold start. Check din yung usok.
You can also consider Nissan Sentra like the B13 or B14. 120k makakabili ka na maayos at mukhang fresh.
September 21st, 2007 08:02 PM #18
September 21st, 2007 08:07 PM #19
Personally I would give a pass on getting Sentra B13s simply because of age. Anyone buying b13s will be looking at a long list of parts of be replaced. It would be cheaper (in the short and medium term) to choose a Sentra B14 model even if they cost more. In the very least, you can buy a B14 that is younger than ten years old.
Of course there are some B13 owners who kept good care of their rides BUT those are exceptions, not the norm.
September 21st, 2007 08:19 PM #20
Some other stuff I just noticed:
-engine bay looks to have been painted recently. Notice the painted bolts on the shock tower.
-front front beside the radiator is colored black (anti-rust primer black). It should be body color. Was it replaced? Front accident?
-the car itself was repainted at least once. You might want to check the quality of the paint job, especially rust at the joints and wheel wells / fenders.
-there is a hydraulic oil container beside the brake booster (left of the booster). Is that connected to the steering system? If so, I assume the previous owner had power steering installed.
-wiper motor. Was it just cleaned or recently replace? It's too shiny.
Daming issue ng SU7:grin:
Xiaomi E-Car
