Results 1 to 10 of 18
- Feb 2010
- 16
February 5th, 2010 04:12 PM #1mga pre -- just recently bought a vios... 1.3J..
what can you say about its clutch? parang hassle ung kailangan mo pang tpakan ng husto ung clutch bago mo sya ma-start... ganon ba talaga dapat un? ung dating vios ba ganon din ang design?
sensya na dami kong tanong... naninibago pa rin kasi ako sa ganitong feature ng vios...
salamat!!
- Sep 2005
- 4
February 5th, 2010 04:44 PM #2its a safety feature designed to make sure you don't accidentally start your car while in gear.
M/T cars in the US already have this feature since the 80s.
February 5th, 2010 05:57 PM #3
Correct.
I actually do this myself, even if I don't have to on my car. If you accidentally start your car while in gear, you might crash into something parked in front or behind you - even with the handbrake engaged. It seems laughable but it's surprising how often this happens.
February 5th, 2010 06:33 PM #4
- Jan 2008
- 4,726
February 5th, 2010 06:43 PM #5the best habit is always check if the transmission is in NEUTRAL position... kasi kahit nakatapak ka sa clutch (for safety prior starting) tapos na start mo na engine... eh naka engage pala yung 1st gear mo kasi hindi mo check prior starting.. pag bitaw mo ng clutch same thing will happen or baka mas worse pa kasi naka idle up pa yung engine mo kasi nag warm up.. mas malakas sipa nun
February 5th, 2010 08:39 PM #6
Yup hassle nga. At first at least.
But think of it this way, pagnakasanayan mo na ang ganitong habit you apply this to any other manual tranny car as a good safety precaution.
This is similar to Pajero automatics - you have to step on the brake to shift from Park to Drive or Reverse.
Good practice.
February 5th, 2010 08:43 PM #7
Not a hassle for the very good safety feature.
Mag DIY ako ng ganyan na feature for my old car, a simple switch for kill switch.
- Sep 2007
- 207
March 3rd, 2010 11:20 PM #8meron ba nakakaalam kung nasaan ang fluid reservoir nitong clutch? hindi ko kasi makita pag sinilip ko yung engine bay eh... kagaya ba siya ng sa altis na share ng fluid ang brakes and clutch?
- Sep 2007
- 207
March 3rd, 2010 11:35 PM #9meron ba nakakaalam kung nasaan ang fluid reservoir nitong clutch? hindi ko kasi makita pag sinilip ko yung engine bay eh... kagaya ba siya ng sa altis na share ng fluid ang brakes and clutch?
March 3rd, 2010 11:54 PM #10
Monk-owned R53
