Results 1 to 5 of 5
- Jul 2010
- 166
October 29th, 2010 10:36 AM #1mga sir, bagong top overhaul po kotse ko corolla xe, nagpalit na rin po ako piston ring. okay naman po, nawala yung mausok sa tambutyo ko, pero after 2weeks kinapa ko yung loob ng tailpipe ko may parang carbon po sya. medyo makapal. bakit po kaya?
- Sep 2008
- 630
- Jul 2010
- 166
October 30th, 2010 09:57 AM #3pero nilinis ko naman po yung tailpipe ko after ko magpa overhaul. after 2weeks nagkaron ng carbon
October 30th, 2010 10:51 AM #4
Kung makapal ang carbon na maitim pa check mo air fuel mixture ng carburator rich ito . Dapat kulay iyong parang nagkakalawang na brown at manipis lang . Pag long driving naman mapupuna mo na namumuti ang carbon sa end ng tailpipe ibig sabihin lang nito maganda sunog ng makina at kondisyon ito . Subukan mong bumiyahe kahit sa NLEX para lumabas ang mga carbon at makondisyon makina mo .Kung city driving lang hindi mailabas ang mga carbon nito.
October 30th, 2010 11:59 AM #5
check the engine vacuum at idle speed, check the ignition timing and check your air induction for restriction. a clogged air filter can do this symptom even for new cars. the air/fuel mixture also, if it is too rich will cause a lot of unburnt or incompletely burnt fuel. if the available voltage from the ignition coil is insufficient or too low, it is unable to provide a hotter spark.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
