Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
    Jun 2010
    #21
    Quote Originally Posted by wrock27 View Post
    sir bago po ecu ko pinalitan na nung nag ondoy so no question about the ecu kasi bago yun maliban nalang kung nag back fire nga dahil sa nasirang mga fuse?
    kung napalitan then no problems na iyan dapat. and hindi para basta-basta masisira ang ECU sa ganung paraan lang so don't worry.
    Quote Originally Posted by grandprix View Post
    Kung ganon, possible na nag karoon ng discontinuity sa electricals or grounding cables during rust proofing application. Try to diagnose with competent mechanic & electrician.
    +1. Electrical shop ang kailangan dito talaga.
    #22
    hmmm... hindi kaya during the undercoating process may tinamaan sila sa engine bay from the underside which causes the problem?
    Nung ako kasi nagpa undercoat, lahat na kailangan takpan sa underside (pati nga sa ibabaw ng engine yata) tinakpan ng mga dyaryo para nga naman kung aksidente ma-sprayan yung hindi dapat eh at least may proteksyon
    just a thought
    Nov 2007
    #23
    +1 electrical shop dyan..
    could be may biglang naputol sa mga relay nyo
    #24
    wrock, check mo nga kung malinis ang socket na nakakabit sa ecu, try daw hugot kabit then start mo uli.
    #25
    and if you checked all that was said here and still it doesn't start.... dalhin mo na sa casa.
    Jun 2010
    #26
    I think hindi rin nila kaya yun with the level of their "mechanics", I recommend an Electrical shop not the Casa.
    #27
    *wrock27
    any update about your avanza?
    Sep 2008
    #28
    Quote Originally Posted by ben_david19 View Post
    first of all I wonder why people do undercoating kung hindi naman binabaha ang sasakyan (except lang kung lumulusong ka wrock sa baha). Avanza ang sasakyan mo so bago pa iyan, may factory undercoat naman iyan. but anyway to your inquiry..
    that is an electrical problem for sure and that is a very rare rare case you have there, either dalhin mo sa casa at kung hindi nila ma-diagnose ng mga incompetent mechanics there, dalhin mo sa Electrical shop like Rey's.
    plus + 1 ako dyan sir, I wonder why ?
    Sep 2009
    #29
    Quote Originally Posted by flying_fox View Post
    *wrock27
    wala pa sir pero ang DIY ko na mga wires ok naman lahat sabi nung electrician sa torino malamang sa ecu ko daw eh sabi ko bago naman yung ecu ko, now naka park vanzy ko sa garage namin hanapan muna daw ng ecu na pwedeng hiramin para malaman kung dun nga
    #30
    wrock, much better try mo ang ecu mo sa ibang avanza...
    or patest mo ang ecu sa casa or baka may kilala ka na may ecu tools...
biglang tumirik at hindi na umilaw ang engine light
