Results 1 to 5 of 5
- Oct 2010
- 3
October 7th, 2010 01:59 PM #1Guys,
I have problem with my Corolla Big Body 94 Model. I am hearing a disturbing sound coming from the dashboard when I am running 60/kms pataas. parang may sumisipol galing sa Dashboard ko. Sinubukan kung umandar na walang aircon pero meron pa rin sipol. Sinubukan ko rin tanggalin ang cassette baka grounded lang pero meron pa rin sipol. Sinubukan ko rin ibaba ang window ko para marinig kung galing sa gulong pero hindi naman. Sa dashboard ko lang talaga naririnig. Tunog mahabang ungot ang naririnig ko kapag na-reach ko ang 60 pataas. Help naman dyan. Thanks.
October 7th, 2010 02:19 PM #2
Tried looking at the outside air vent sa slider controls ng A/C? Bka di na nagsasara yun ng mabuti, and it makes some sense since kailangan air has to be rushing in para sumipol ang hangin papasok. Try leaving it at the outside air setting to fully open the vent and see kung ganun pa rin.
- Oct 2010
- 3
October 7th, 2010 02:28 PM #3Ita-try ko po ulit. I'll reply to this post kung ganun pa rin. To recall, I think ginawa ko na yan nung nagpunta ako ng subic. Binuksan ko yung air vent pero meron pa rin akong narinig na sipol. Ang weird lang sa akin bakit every 60 up ko lang naririnig ang sipol kasi kung talagang malakas ang hangin kahit 30 pa lang takbo ko dapat marinig ko na sya. Thanks po ulit sa reply. God Bless.
October 7th, 2010 02:52 PM #4
Maybe the wind is not going through strong enough at 30kph? I know mabagal pa ang takbo ng XE ko at 30 kph. I know kasi yun ang speed ko pag umaakyat sa parking lot :D Pero iba na ang 60 medyo matulin na yun.
Try mo i-move from side to side yung lever baka na-stuck up yung takip ng vent sa slightly open na position. Try mo rin ilagay yung vent controls to Windshield to blow debris off the vent. If it persists palinis mo yung aircon para mababa yung dashboard and see if anything's blocking the vent.
- Oct 2010
- 3
October 7th, 2010 03:37 PM #5Salamat po sa advice. By the way, kakapaandar ko pa lang now. I still hear the disturbing sound sa dashboard. I will take your advice ipapalinis ko yung aircon..papabuksan ko yung dashboard baka nga nandun ang problema ko. Ask ko lang ulit... Di naman kaya sa transmission, engine or wheel bearing? I doubt it din kasi na ganun nga dahil maayos pa ang takbo ng oto ko. Wala ako naging problema sa makina. yung ingay lang talaga medyo kainis. Salamat ulit sa post.
You can add , The Ten Commandments, BenHur ....
Traffic!
