Results 1 to 8 of 8
    Apr 2010
    mine is lovelife xe w/stock 2e engine.should i stick to original{oem} s.plug spec. or upgrade? any suggestion is welcome. regards!
    2E lang ba yan ?
    Stick with Denso's. Cheap pa.
    NGK na lang japan made pa ewan sa denso baka thailand lang
    Dec 2010
    dipende n sau un if your after the price pick ngk pero kung s perf i prefer platinum ng bosch.. mdugo nga lng..
    Go for NGK; i think we used BKR6E or BKR5E on our 2E before and it worked okay.
    What's important is that you just use what is specified by the manufacturer, its gapped to spec, and change as required (i.e. every 10,000kms). No need for platinum or performance plugs really.
    If you want more power or response then you can try use a colder plug (i.e. NGK BKR6E), advance your timing a bit then use higher octane fuel (to avoid detonation or tope from the advanced timing).
    Japanese engine must use a Japanese spark plug !!!
    NGK gamit ko sa 2E engine ko .
    Apr 2010
    [SIZE=3]thanks amigos! more please.[/SIZE]
best spark plug for xe '98?
