Results 11 to 19 of 19
September 2nd, 2016 02:29 PM #11
If the coolant is going down it is probably caused by a leak, check the coolant hoses for residue. Change all the hoses and clamps if you can find the replacements. Worst case scenario is a gasket leak.
If you want to drain the coolant, most radiators have a plastic drain plug. You can flush the radiator and replace with 50/50 coolant mix.
- 52,731
September 2nd, 2016 02:29 PM #12wala akong avanza.
but ayon kay google, merong radiator drain yan. google nyo po. mukhang simple lang naman, base sa pictures. (hirap basahin yung indonesian {malaysian?} lyrics.)
errr... nawala na ba ang owner's manual, po? nandun yata ang instructions.
walang kuneksiyon ang radiator coolant sa aircon.
but, some cars' aircons are designed to quit when: 1. low on freon; 2. overheating engine, for whatever reason.
good luck, po.
paayos? depende kung ano ang sira, po. maraming puedeng mangyari, e...
kung gagananciahin, low on freon lang.
kung mamalasin, may leak sa kaloob-looban ng sasakyan na hindi mahanap-hanap.. palitan lahat ng tubing! or, may leak ang compressor mismo! heh heh.Last edited by dr. d; September 2nd, 2016 at 02:32 PM.
- Jun 2005
- 3,774
September 2nd, 2016 05:08 PM #13Kung di ka sanay mangalikot sa kotse mo, pagawa mo na lang tapos panuorin mo paano.
Madami nasisira sa pagtitipid. Personally, madami na ako nasira pero considered "tuition" ko nlng sya sa exprience. Hehe
- Apr 2011
- 2
August 28th, 2017 10:19 PM #14Good day mga sirs/mam! Ask ko lng regarding s coolant ng avanza ntn. Malapit na kasi mag low yng coolant ng vanzie ko. Plan ko xa lagyan. Pwede po b yng nbli ko n Long Life Coolant Pro 99? Or anyone here n nka try n po nun? Thank po sa sasagot. God Bless us all!
Sent from my SM-A720F using Tsikot Forums mobile app
- Feb 2014
- 2,536
August 28th, 2017 10:34 PM #15
- Apr 2011
- 2
August 28th, 2017 11:21 PM #16Yes sir. Pink nga yng nbli ko. Pwede kya yng brand n Long Life Coolant n nbli ko sir? Thank you s pagsagot sir.
- Feb 2014
- 2,536
August 28th, 2017 11:34 PM #17
original coolant mo is toyota pink? this is the super long life coolant, lasts many many years. check your manual
top up w/ toyota pink coolant only. don't mix
when it's time to replace the coolant, use toyota pink coolant only
don't experiment w/ coolant, not worth the risk
- 52,731
- Feb 2014
- 2,536
August 29th, 2017 02:04 PM #19
