Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 63
    May 2005
    #41
    That's why it's not sold in Japan... it's well below of Toyota's own standards. It's a vehicle designed to make money(Toyota IMV project is well advertised in Discovery Channel), not designed to make an awesome one. POS. Perhaps if Jeremy Clarkson would come across one, he would probably beat it with a sledgehammer.
    #42
    Quote Originally Posted by bilog
    will the bigger rims setup messup the braking capability of the fortuner?
    the mass will be moved outward from the center with bigger rims, hence increasing rotational inertia.
    check this explanation about rotational inertia from http://www.newton.dep.anl.gov/askasc.../phy00124.htm:
    Rotational inertia is a resistance to change of rotation. The more
    rotational inertia an object has, the less it responds to being spun. The
    outside parts of a spinning object have to move much faster than inside
    parts near the axis. How an object is built, and along what direction you
    want to spin it, also affect the rotational inertia.
    and conversely, it could apply to stopping the object's rotation.
    other link: http://www.analyticcycling.com/WheelsInertia_Page.html
    #43
    Ayon din sa Thai forums, ang cause daw ng brake problem ay sa mods ng rim size. 20" and bigger yata ay delikado na sa stock brakes ng Fortuners.
    Im not so sure how this affects the brakes. Pero here are the links sa Thai forums:
    http://www.thaivisa.com/forum/index....10&hl=fortuner
    another thread: read the posts by "Emilio" on brakes, mods and rim sizes
    http://www.thaivisa.com/forum/index.php?showtopic=51174
    Hope this helps............
    Mar 2005
    #44
    Quote Originally Posted by shockz
    *shockz: This is great information! Kaya fellow fortuner owners who've done mods on your tires, mags and brake systems... Monitor the effects of your modifications and be mindful of your driving habits.
    #45
    Quote Originally Posted by boybi
    hehe, mabuti nalang at may patrol na ako nung nilabas ang fortuner
    YABANG!! bwahahahahahaa :bwahaha:
    a bit of a stretch naman yung mga accusations na yung fortuner is "not sold in Japan because quality isn't up to snuff". hindi naman yan yung criteria para ibenta sa japan yung sasakyan
    #46
    Madami din namang labas na panget sa Japan and be glad those vehicles were for JDM consumption only. The Toyota IMV project was NEVER intended for Japanese consumption but it does not mean Toyota will intentionally make a lemon.
    Pero ang hina naman yata ng Fortuner kung 20" rims lang hindi pa kaya hawakan. Pano mo lalagyan ng off-road tires iyan?
    #47
    Sabihin na natin na maybe isang reason nga yong modification to the tyre rim installing 20" rim kaya nagka problema ang thai Fortuner owner sa brakes nya.
    Pero paano explain ng Toyota yong result ng BEISSBARTH brake tester sa brakes ng Fortuner showing 45% efficiency at iba pang mga negative results. Stock tyres ang sure na ginamit for the test at di 20" rim.
    #48
    i just drove a friend's fortuner a few minutes ago, mas mahina nga ang brakes nya compared to other cars i've driven.
    Signature
    #49
    hmm... mahina preno... fortuner owners, kabitan niyo nalang ng wang-wang yung mga sasakyan niyo hehe :bwahaha:
    May 2005
    #50
    Is it because of the momentum from a heavier body that's causing the brakes to not work properly? Its also probably because Toyota tried to scrimp so much that they replaced the rear ones from discs to drums and selling it to people for the same price as discs! :D
Ano ba na naman eto???Toyota Fortuner's had brake problem in Thailand.
