Results 11 to 13 of 13
- Nov 2008
- 641
December 13th, 2013 11:17 AM #11Sir nori,
Ayos at nakita mo na problem. Have you tried checking the cylinder head bolts kung mahigpit? Better check it with a torque wrench. Kung cylinder 4 ang may leak, dapat kasi di basta basta affected si cylinder 3 kung gasket lang ang problem. Maaring di nahigpitan ng maayos before? Just in case magpaapalit ka ng head gasket, its best na isabay na din yung re-seat (grind kung ok pa) at palit valve seals. Medyo mahal din kasi labor. I think gagastos ka diyan ng 4k to 6k (parts & labor). Good luck!
"also, di kaya fake yung replacement gaskets na kinabit dati? aside sa leak na nakita ko, may soot na namumuo sa bandang port ng intake manifold." - sign of leak also
- Sep 2013
- 505
December 13th, 2013 01:47 PM #12
- Sep 2013
- 505
December 16th, 2013 06:13 PM #13done repairs. turns out the intake manifold to port #4 is cracked and broken. i had the aluminum manifold welded, replaced the gasket and voila! all cylinders are alive and kicking again. =)
still have a little vibration though. so... normal na ba to sa 96 model na sasakyan with an old design engine?
