Results 791 to 800 of 1371
January 2nd, 2017 03:19 PM #792
Yup, try the Maxcover or Topup lids with full vertical lift. You can also consider what I did which is the Carryboy Soft Lid then a lockable utility box mounted inside (try Maxbox or Aeroklas).
The roller lids turn out to be problematic in the long run based on comments over the years that's why I did not go with that.
- May 2016
- 546
January 2nd, 2017 05:19 PM #793I opted for the roller since I occasionally carry tall items. Carryboy rollerlid costs 30K+ only with warranty if you get it from their shop. There's a cheaper gator roller for around 25K+, just thinner aluminum but does the same job. Get the flat canister design, those are the newer ones. Leaks are minimal if properly sealed, just at the tailgate and under very heavy downpour. Just need proper maintenance, clean the canister every month to avoid leaves and debris build up, and spray lubricant, silicone grease on the railings every week. I've had mine for a few years now and it's holding up fine. Just get the manual version, it's the motorized that has problems.
January 2nd, 2017 06:53 PM #794
- Nov 2009
- 173
- Apr 2014
- 96
January 3rd, 2017 12:31 AM #796
January 4th, 2017 03:02 PM #797
Roller lids are a hassle and costly to maintain ... use this option as a last resort ... most people won't have the time nor exert the effort to regularly lean and maintain the roller lid mechanism ...
January 4th, 2017 05:23 PM #798
Sobrang problematic yung roller lids from Carryboy. Yung pinsan ko 1 year lang leaking na yung water kaya half-opened nalang. Kaya he recommended me to just put canopy pero limited nga lang vertically yung pwede ilagay.
- Apr 2014
- 96
January 5th, 2017 05:38 PM #799Dang. Was already leaning towards the roller lids but now I gotta reconsider. Doesn't Carryboy have a warranty to cover for defects like leaks?
Hirap pala pumili ng bed cover. Haha!
January 6th, 2017 09:29 AM #800
They'll give you 1 or 2 years warranty but after that it's the same banana ... headache when it leaks and gets stuck ... they offer cleaning and maintenance service of the roller lid for about 1000-1500 and you do it annually ...
