Results 781 to 790 of 1371
- May 2009
- 66
December 17th, 2016 08:51 AM #781Hi. Hilux revo owners.
May issue ako 4x4 MT, kapag nag shift esp to 3rd gear/4th, medyo may maingay and medyo matigas. Pero hindi siiya ung sound na hindi naapakan ung clutch ng tama. Parang mga ball joint na sumasabit. Dinala ko na sa casa sabi, same sound din sa same models na new hilux. May na exp na kayong ganyan?
Isa pa pala, pahelp pag tangal ng front grill. Nag buy kasi ako trd grill, hindi ko matangal ung old grill. Natangal ko na 5pcs metal screws, pero parang may clip lock pa sa lower part. Natatakot ako puwesahin kasi baka masira.
Thanks
- May 2016
- 43
December 18th, 2016 10:25 PM #782Hello SIr,
yes, i also encounter the same with my 4x2 E manual. ung gear e parang mag lalock and its hard to change gear. nangyayari to sa akin tuwing matagal na banat akyatan. as in high speed akyatan ndi ko na sinasabi sa casa kase tuwing mgay na rereport akong napapapansin ko sa unit ko e puro normal lang daw.
- May 2016
- 45
December 19th, 2016 01:07 AM #783Naalala ko, with normal traffic, may pinadaan ako sa pedxing. Nag Neutral ako, the moment na Go na daw, hirap na hirap akong ipasok sa 1st gear, ayaw ko naman pilitin baka masira kako. Took me 4-5 times or more bago maipasok.
The 2nd time na na encounter ko nanaman, still on pedxing. Pero ang ginawa ko nag 2nd gear na ako agad para maka abante. Until now hindi ko pa ulit na experience mahirap ipasok ang primera.
- May 2016
- 43
December 20th, 2016 12:03 PM #784na encounter ko din yan multiple times sir. ang ginagawa ko is double pump ko ung clutch at kung ayaw parin e mag 2nd gear muna ako tas balik sa 1st gear. ung change gear sa bagong hilux e ndi smooth. parang may sumasayad. para kang nag cchange gear sa lumang jeep or truck. tas may tunog pa.
- Apr 2014
- 96
December 30th, 2016 03:03 AM #785Anyone here know the price for roller bed cover? What's a good brand to buy? Thinking of Carryboy. Also, san magandang magpakabit? Hirap kasing maglagay ng gamit sa likod ng Hilux pag walang cover eh, kailangan bantayan lalo na pag traffic at baka may humablot pa.
Thanks in advance mga sir! Happy New Year!
January 1st, 2017 09:08 PM #787
Try the Tri-fold cover. Less likely to leak and have issues later on. Atoy has for the Revo and it's discounted at 21K until the 3rd or 4th of January.
I'm using a Carryboy Soft Lid on mine with a lockable box inside.
As for the shifting, mine has no issues although I noticed the start-up or shut-down shifter vibration is stronger when the car is on an incline.
- Jul 2016
- 939
January 1st, 2017 09:55 PM #788If naka patay ba makina madali naman ipasok 1st gear?? If madali...
Usual cause nito is pressure plate or bent clutch disc. Nagcocontact pa rin ang clutch disc sa press plate and flywheel eventhough naka fully depress ka na sa clutch dahil nga bent/warp na sya. This will cause to spin the input shaft and counter gear ng tranny at nahihirapan pabagalin/pahintuin ng synchronizer rings ang 1st gear.
It is up to you to decide. Accept it na lang, antayin mga 150t kms para maupod existing clutch. Or push casa to hoepfully they replace it(not sure if covered and clutch ng warranty, alam ko di ata.)
For the meantime, wag nyo pipilitin ipasok. This will cause premature wear sa 1st gear synchro and/or bent 1st/2nd gear shift fork.
- Jul 2016
- 939
January 1st, 2017 10:01 PM #789
- Apr 2014
- 96
January 2nd, 2017 02:48 AM #790Thanks vinj! Checked it out but I'm not a fan of how it looks and the absence of a locking mechanism. The roller lid still looks a lot nicer for me. Have yet to visit Banawe but based on my online research, the roller lid costs around 35k++, is this correct or medyo mahal/mura? Read in the Mitsu thread though that roller lids do not offer complete protection from water leakages in case it rains.
Do you have other suggestions for bed covers? Also considering the Aeroklas deck cover but maybe it's the last option because (1) it's more expensive; (2) it looks too bulky; and (3) it limits bed use due to its vertical movement (can't have people staying on the bed for beach trips and outdoor barbecues which we do often)
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
