Results 861 to 870 of 1371
March 10th, 2017 09:17 PM #861
- Jul 2016
- 126
March 10th, 2017 10:56 PM #862
March 10th, 2017 11:14 PM #863
You can still use the steel spare and get the same diameter as the 4 wheels, although most likely the offset will be more negative for the 4 wheels.
For me unless you have 5 identical rims you can keep in rotation as they wear out, sayang lang yung magandang tire as a spare. In my pickup I've run 70Tkm+ and I've only gotten a flat 3x. Naluma lang yung spare tire, had to replace it with a new one. Unless ok lang sa yo isama sa rotation ibang itsura na rim na same din ng specs.
- Jul 2016
- 126
March 11th, 2017 01:06 AM #864
- Jul 2016
- 126
March 11th, 2017 01:09 AM #865
March 11th, 2017 07:55 AM #866
Yup, for example if your 4 tires are 265/50r20, it is the same diameter as 245/75r16, which you can use on the steel rim. Having the same overall diameter tire won't damage the differential if you use it on the rear axle.
But of course it is better to have a spare that is the same as the rest for stability and consistent grip.
March 11th, 2017 08:18 AM #867
Treat the spare as a donut. Only use it until you vulcanize the punctured tire.
Even if you want to waste your money on a spare tire that's also upsized, most tire shops don't sell rims in sets of 5.
March 11th, 2017 11:05 AM #868
- Jul 2016
- 126
March 11th, 2017 02:06 PM #869
- 52,700
March 11th, 2017 09:14 PM #870Originally Posted by ;2810688
mebbe the "tusok"-type repair kit.
also, you might consider a second spare tire in your vehicle.
