Results 8,831 to 8,840 of 8993
December 7th, 2017 06:29 PM #8831
Wala po, lagi syang inspect lang dun sa PMS schedule.
May nakalagay din dun sa dip stick ng atf na no need to change... which parang ang hirap paniwalaan kasi based dun sa mga napapanood ko maganda na partially palitan sya from time to time. Partial lang naman po plan ko (4L siguro) di naman po full dialysis na lahat ng ATF. Aabot ata ng 10-12L yung needed ATF pag dialysis method.
Nung naginquire po ako 900+ yung 4 liters sa Toyota.
December 7th, 2017 06:35 PM #8832
good price. better than the motul cvt-fe
as per malaysian vios pms:
cvt fluid replacement is 48mo or 80,000km whichever comes first.
for our stoopid ass traffic i would do 36mo or 60000km whichever comes first.
December 7th, 2017 06:40 PM #8833
December 7th, 2017 10:51 PM #8834
4at uses non-long type fluid (and its only 3 liters) kaya 40k or 24months.
the cvt fluid is 7+ liters and its long life imo..
December 11th, 2017 11:41 AM #8835
- Dec 2017
- 1
December 11th, 2017 09:04 PM #8836yes sir, camber is always offset to the negative... a negative camber gives that "pike" look to the front tires it has something to do with the geometry the front tires make when turning. toe in and toe out on the other hand should read the same on both tires, "0" is a baseline reference at right angles against the spindle. matching both tires with the same reading.
December 27th, 2017 11:17 AM #8837
Good Morning, I have a 4 y.o. gen 3 vios E AT with 48K Kms. Still stock brakes which were last inspected/cleaned 8 months ago (40K kms). Lately may naririnig akong squeling sound kapag nagpepreno ako during reverse. Ang weird lang kasi wala akong naririnig kapag paabante ang takbo. Mukhang sa weekend ko pa maiipacheck kasi may trabaho pa till Dec 29. May nakaexperience na din ba sa inyo nito? Thanks
January 4th, 2018 05:03 PM #8838
Guys, need some help...
I have a Vios 2013 and brought it to Toyota Dasma to have the steering checked. There is a "clacking" sound when turning left or right.
Upon checking, casa is saying that the rock and pinion needs to be replaced, along with the shock absorbers and other suspension parts. Quoted price is P70K+. Wow!!!
I would like to seek a second opinion from another reputable shop. Can anyone recommend a good shop that could validate these and do such repairs in the Cavite area (i.e., Imus, Dasma, Kawit or Las Pinas area)?
Would appreciate any recommendations, exact location plus contact info. Cheers.
- Aug 2013
- 475
January 4th, 2018 05:09 PM #8839Sir, meron ako recommend kaso paranaque area.
JPWheels Center. pwede mo search sa FB.
free check up naman, pwede ka sa labas bumili parts or sila mag source for you.
tutal nasa paranaque ka na, nandun si Cruizer parts at RPMS para sa OEM/replacement equivalent nung mga kailangan mong palitan.
kung same lang rack and pinion ng 3rd gen at 2nd gen vios, P4500 bili ko sa Cruizer ng taiwan replacement. halos 3yrs na, ok pa siya.
January 4th, 2018 05:18 PM #8840
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
