Results 8,631 to 8,640 of 8993
- Jan 2013
- 149
September 4th, 2016 01:59 PM #8631
September 6th, 2016 06:28 PM #8632
mga bossing
tanong ko lang po, ok lang po ba mag top up ng coolant / washer fluid?
no need to drain, ihalo ko lang yung current na laman dun sa bago?
September 6th, 2016 06:49 PM #8633
- 52,700
September 6th, 2016 10:12 PM #8634iba po ang coolant fluid. iba rin ang washer fluid. iba ang mga sisidlan nila, kahit na magkatabi kung minsan.
may upper and lower marks ang coolant reservoir. keep the liquid within those marks.
ok lang naman na maubusan ng windshield washer fluid. walang masisira. mai-inis ka lang sa sarili mo, at baka mabangga ka, dahil hindi mo malinis-linis ang windshield habang nagmamaneho, dahil pinayagan mong maubos siya.
no need to drain, unless the fluid is dirty.
- Jan 2016
- 58
September 7th, 2016 12:19 AM #8635Any feedback and reviews to the new dual vvt-i engine?
sent from the other side
September 7th, 2016 07:02 AM #8636
Remember to use DISTILLED water only for windshield washer and Coolant / distilled water mixture for radiator ...
Please please please take time to read your vehicle's operating manual instead of updating your social media ...
September 7th, 2016 08:53 AM #8637
salamat po
i did read the manual naman po, and it specifically states there not to use water
bale gusto ko lang po sana iconfirm kung no need na iflush yung coolant (i had the notion na same with engine oils, you need to drain and replace with new)
- Jan 2013
- 149
September 9th, 2016 09:57 AM #8638magkaiba ang lalagyan ng coolant at lalagyan ng washer fluid. magkaiba function nila. Pag msyado mababa coolant level mo punta ka toyota pa check mo for possible leak. for windshied washer fluid, mga 90Php+ ata ung 1 liter sa toyota to be diluted with 1liter na tubig kaya magiging 2 liters na washer fluid yun.
- Sep 2016
- 1
September 16th, 2016 11:33 PM #8639Hi, newbie driver here -2 weeks to be exact . I really dont know about cars..2x na naddrain yung batt ko, the first time is naiwan ko daw ang park lights, the 2nd time kanina - I really don't know the reason - I checked if all the lights were off -- turned the stick in off mode naman. Few questions lang:
1. how will i know if may mga naka open ako na lights? wala naman kasi signs sa dashboard pag nakaopen parklights. yung signal lights and high beam lights and fog lights lang. ---read the manual, wala naman nakalagay
2. how to i change the clock?
3. may bluetooth ba ang vios 2014?
- 52,700
September 16th, 2016 11:55 PM #86401. the lights are very visible if they are on, po. one has but to look. some cars, vios included yata, will emit a soft whining sound if the keys are left in the slot or the lights are on, when you open the driver door.
2. digital? for hours, just press the "H" button, and the numbers start scrolling. for the minutes, press the "M" button. it's just a casio digital watch at heart.
3. bluetooth? lookit the icons, po, on the front of the radio, kung meron. also, the manual should be helpful.
now, the battery.
if you say all them lights are off and the battery still dies, my guess is, that battery is dying. how long has that battery been in the car? bring the car to the battery shop and they can test it to see if it is, indeed, dying. be ready with money, so that you can buy that new battery then and there.
