Results 11 to 20 of 23
- Mar 2004
- 652
February 18th, 2010 12:42 AM #11OK bro. Ingat lang sa pagmaneho, lalo na minsan malibang ka, e, naka 140 ka na pala. Have tested my gli before, and it runs to 180 easy even with the A/C on (kinarera ko kasi BMW sa Macapagal hi-way, 11:30 AM on a saturday kaya very light ang trafffic ). Also, diyan sa kanto Osmena-Quirino, meron pa rin diyan nangtatanggal ng side mirror.
- Mar 2009
- 25
February 21st, 2010 08:56 AM #12hehehe nakakatakot na yun sir. 120 max lang ako hehehe baka makalas makina ko. haha salamat paps.
May 23rd, 2011 03:19 AM #13
Mga sir, may oil leak din ung distributor mismo ng 4afe corolla ko. I have it repaired once and the mechanic changed the O-ring and the oil seal inside the distributor, after almost 2 months, may leak ulit. I wonder since di naman nya dinala sa machine shop ung ditributor. What he did was he opened the distributor then kinalas lahat nung nasa loob, then he removed the shaft then removed and replaced the oil seal inside. Replacement seal lang ang ginamit since wala rin akong mahanap na orig oil seal and o-ring. What went wrong kaya with the fix? Is it dahil hindi dinala sa machine shop or so?
Any suggestions where it can be checked and repaired?
Where can I get original seals? I went to Gant and Partstar sa Pasay and replacement lang daw meron.
Thanks in advance!
- Jan 2011
- 25
August 4th, 2011 04:53 AM #14Sir,
May shop ba kayo? i've read na nagchecheck kayo ng distributor, since malapit lang kayo sa location ko, baka pwede ko pa check sa inyo yung kotse ko, corolla ae101 gli, medyo humina kase yung hatak nya, baka distributor yung problem, plus ung tachometer ko di gumagana at nagloloko minsan yung speedometer.
If you have contact details, let me have it.
Thanks!
- Aug 2011
- 1
August 13th, 2011 12:44 AM #16lumipat ata sila ng location. di ko na malala kung sa-an kasi meorn naka paskel sa pwesto nila. try mo hanapin sa direktoryo.
bmw service
- Apr 2010
- 97
September 2nd, 2012 05:03 PM #17up ko lang po ito, meron po bang condenser ang distributor ng 4afe ae101? sakin kasi wala syang condenser at nag eestumble yung engine pag nirerev ko. niremedyo lang sa spark plug gap para maminimize yung stumbling engine. pero hindi ideal yung gap. kaya duda ako baka dahil walang condenser yung distributor ko. sa inyo po ba meron nitonh condenser? 95mdl po yung oto se limited gli. thanks
- Jul 2004
- 59
August 18th, 2013 02:05 PM #18
- Apr 2010
- 268
August 18th, 2013 03:06 PM #19Sa Gant Auto sa may taft ave malapit sa lrt edsa station. Original toyota parts. May mekaniko na rin dun.
Peace out!
- Jul 2004
- 59
August 18th, 2013 03:23 PM #20
Traffic!
