Results 61 to 70 of 98
December 9th, 2022 12:27 AM #61
If I may make a suggestion. Several years ago all my dashcams are hardwired, meaning i had it tapped to a wire or a fuse. Until about 2 years ago I heard and tried of using the obd hardwire method. You line up the wiring normally on the pillars then connect it to the obd port of your vehicle via a kit. Comes with a switch also so you can leave it on if in a mall parking or whenever you want to with the engine off or auto off when you turn off the engine. No splicing, no tapping. Just plug it in the port since the ports are standard across different vehicles. You just need to look for the location of your obd port. It's usually near the foot well, driver's side. You can remove it easily if the casa needs to access your obd port.
Sent from my SM-P615 using Tsikot Forums mobile app
- Sep 2010
- 2,866
December 9th, 2022 12:58 AM #62
- Nov 2019
- 972
December 9th, 2022 11:46 AM #63Why not buy a ciggarette lighter slot to USB converter para ma connect dashcam from USB cable?
I think most Dashcams are USB male plugs that are only connected to the USB slot of cigarrete lighter to USB converter. Hindi pa ako nakakita ng Dashcam na ang male plug is cigarette lighter slot.
July 28th, 2023 11:04 AM #67
Toyota could be releasing new Veloz E variant priced at P1.092-M | TopGear PH
The soon-to-be base Veloz will come without puddle lamps on the sides and without overfenders on the wheel arches. The latter has supposedly resulted in a 5mm reduction in overall width. This new trim will also come with 16-inch alloy wheels, a tad bit smaller than the current 17-inch alloys on the G and V trims.
The Veloz E, however, will share a few components with the G, such as the eight-inch infotainment system with Apple CarPlay and Android Auto. It’ll also still have a wireless charger and a reversing camera with rear parking sensors. No Toyota Safety Sense here, though.
- Sep 2015
- 212
Tsikot Member Rank 3
- Nov 2002
- 1,890
July 28th, 2023 02:02 PM #69
October 14th, 2023 02:26 PM #70
Is it hard to get a Veloz? need to reserve early? will get one on January.
