Results 671 to 680 of 780
- Jul 2016
- 939
September 16th, 2016 05:29 PM #671Thanks sir sa info. Mukhang software fix nga lang ito.. Swerte mo sir di nagalaw tranny mo, imagine luwagan nila screws, connectors, clips, etc... hoping na maibalik at matetorque ng maayos on a fairly new car.
Yes. Same lang. Software update, ECU and TCM module/computer re-flash. The name "flash" is the term for the memory chip na gamit ng ecu/tcm, dito naka store ung code command/software. Older cars/ECUs uses EEPROM chips. Different terms lang pero same thought.
Parang inupdate lang ang celfone OS like android or iOS. ng mga CP natin or windows sa PC to fix some bugs and have some improvement. Tranny kasi ngaun fully electromechanic na, controlled na totally ng computer mga solenoid, position and speed sensors para maging smooth shifting unlike before na lahat mechanically driven.
- Aug 2016
- 10
September 17th, 2016 09:36 PM #672[QUOTE=Janemar;2766985]Thanks sir sa info. Mukhang software fix nga lang ito.. Swerte mo sir di nagalaw tranny mo, imagine luwagan nila screws, connectors, clips, etc... hoping na maibalik at matetorque ng maayos on a fairly new car.
Parang inupdate lang ang celfone OS like android or iOS. ng mga CP natin or windows sa PC to fix some bugs and have some improvement. Tranny kasi ngaun fully electromechanic na, controlled na totally ng computer mga solenoid, position and speed sensors para maging smooth shifting unlike before na lahat mechanically driven.[/
Up ko lang yun thread mga sir para sakaling mag post yun mga iba p na naupdate ECU na naging Ok n unit nila... Salamat po
- May 2016
- 89
September 17th, 2016 10:55 PM #673
- Aug 2016
- 10
September 18th, 2016 07:09 PM #674
- May 2016
- 89
September 18th, 2016 07:15 PM #675
- May 2016
- 89
September 18th, 2016 07:19 PM #676
- Aug 2016
- 10
September 18th, 2016 08:13 PM #677
September 18th, 2016 10:00 PM #678
My Tranny was first changed but still jerked... Confirmed by the tech guy and had the ECU updated. May slight downsift braking pa rin. Complained about it but their tech guy say no anomalies appeared in their laptop. Normal na daw. If you are a passenger, di masyado halata.
- Mar 2016
- 164
September 19th, 2016 12:44 PM #679
- May 2016
- 89
September 19th, 2016 03:46 PM #680sO tama ba sir, yung syo meron pa din after ma ecu update but not like before? feel of downshift sa makina. as per tmp daw ksi depends sa production date ng tranny. if 16e daw still needs update, but it if 16f already modified na daw.
Daming issue ng SU7:grin:
Xiaomi E-Car
