Results 5,171 to 5,180 of 5286
- 52,731
December 26th, 2019 04:29 PM #5171since you do not have a full-tint front windshield, you are not the intended target.
good luck with your retrofit, po.
kindly remember the oncoming motoristas. it is not right to improve one's night vision, at the expense of these folks' ...
i have innova, and its factory headlights are fine with me.
just do not expect them to light up the world, like what the sun does.
'tis common knowledge... do not drive as fast at night, as one does in the daytime.Last edited by dr. d; December 26th, 2019 at 04:36 PM.
December 26th, 2019 04:38 PM #5172
haha sounds like a big no for LED then. TBF, the innovas stock reflector housing is huge and looks designed well. My 2011 hilux is also reflector only, and with nightbreakers its really bright, far brighter than the halogen projectors of the new fortuner.
I'm just looking for a better way to drive at night, even driving slow, if you can't see the road it is dangerous sir. No offense meant sa reply ko, and I hope none taken. If you notice kasi, the stock lights of the G forty barely light up the road, and while the throw is far, enough to light up reflectorized signs well, it does not give you enough feedback to drive confidently at night. Just came from Tagaytay the other night kasi, during heavy rain, and it was pretty bad with the stock lights. Really frustrating boss!
- 52,731
December 26th, 2019 04:46 PM #5173if one's factory headlight beams are "sabog" or un-directable using the headlight assembly's aiming screws, try if the ff:
1. the bulb might be improperly seated;
2. cataract-ic lenses already.
- Apr 2009
- 429
January 7th, 2020 01:04 PM #5174
- Dec 2010
- 46
January 7th, 2020 01:52 PM #5175Hello po - Ask lang po sana ako ng tip as I'm a new fotuner 2016 user. Napansin ko lang po na nababwas ang coolant.nag check po ako pag morning before using mababa na sya sa L pero normal level pag maninit napo yung engine. Normal po kaya ito? Maraming salamat po.
January 7th, 2020 02:59 PM #5176
^that's normal..a running engine is hot..heat generates pressure that causes some of those fluid to overflow or evaporate..when the engine is off the ideal fluid level should be at F..acceptable level is in between F and L..below L you should fill it up with distilled water up to F
- 52,731
January 8th, 2020 12:56 AM #5177liquids, including coolant, expand and contract with heat and cold, respectively.
when the engine is hot, coolant expands and overflows to the reservoir. "mataas".
when the engine cools, coolant contracts and pulls the coolant in the reservoir, back to the engine. "mababaw".
measure reservoir level in the morning, when the engine is still cold. keep the level between full and low.
January 8th, 2020 11:28 AM #5178
- Dec 2010
- 46
January 8th, 2020 10:34 PM #5179Noted po mga sir/s. Maraming salamat po. Nakaka kaba kasi dahil kakapalit ko lang po ng 2 front shocks dahil nag leak na yung isa at 20K kms then nagbabawas pa ng coolant. Obserbahan kong mabuti yung coolant level muna.
- Dec 2010
- 46
January 8th, 2020 10:37 PM #5180kahit distilled water nalng po pang dagdag sa coolant or need pang bumili ng coolant sa kasa para same lang sila?
