Results 4,161 to 4,170 of 5286
- May 2006
- 32
March 3rd, 2018 10:44 PM #4161Hi GTCervan,
Pwede pa din.
Ibaba mo sa S1 para locked siya sa 1st gear. Tapos angat mo sa S2 pag match na ang engine rev at speed. Panik mo uli sa S3 pag pwede na 3rd gear. Upshift ka uli sa S4 pag match uli. Do it until S6.
In other words, nag lo-lock yung gear according sa pinakamataas na ni-set mo.
Thanks,
ShortRider
March 3rd, 2018 10:51 PM #4162
- Mar 2014
- 2,127
March 3rd, 2018 10:57 PM #4163
- May 2006
- 32
March 3rd, 2018 11:41 PM #4164you are absolutely right buddy! not confused at all. [emoji16]
i think that design will minimise engine/transmission wear/tear due to unmatched rev and speed. [emoji1303]
once i made an error downshifting at high speed and it did not allow me. [emoji1317]
Note: the Ford Everest behaves the same way.
March 3rd, 2018 11:44 PM #4165
Sir you can upshift and downshift by yourself using the shifter or paddle shifter. Yung sa akin lng kasi, I'm just testing the shifter, kasi mula nung binili ko, I haven't used it kaya dun ko lng na notice na habang nakahinto yung fortuner ay nasa S4 na siya, pero usually, I'm using the paddle shifter if I'm overtaking but bihira lang.
Sent from my ONEPLUS 5 using Tapatalk
- Mar 2014
- 2,127
March 3rd, 2018 11:59 PM #4166Okay so pwede pala. Lol thanks. I currently don't have a Fortuner pero I like to have one in the future. I relied on the review of CGPh lang kasi when the guy there said that it's not a pure manual override. Kaya na-curious ako as to how the manual mode of the Fort would operate. Now I know na. Maybe I'll try din once there is a test drive festival sa MOA.
March 4th, 2018 12:02 AM #4167
Medyo weird ang Toyota paddle shifter. If for example you put it in 4th manually, it will choose any gear from 1-4, not necessarily 4th gear only. If you put it in 3rd, it'll choose from 1-3. That is, pag masyadong mababa yung speed for the gear, it'll pick a lower gear.
- Mar 2014
- 2,127
March 4th, 2018 12:06 AM #4168
March 4th, 2018 07:12 AM #4169
- Mar 2003
- 82
March 5th, 2018 11:50 AM #4170Question for those who have Gen2 Fortuner Manual transmission.
I have noticed recently that the stick shift vibrate too much that create annoying noise (like there are marbles inside the transmission) during start up. Tried to hold the stick shift or put it on 1st gear while starting so it wont play much during start up and the noise is gone or reduced to minimum. Not sure if this is normal for the manual tranny. Got the Fort 2nd hand so I would like to know if this is normal or need to visit casa to have this checked.
Thanks
Automatic po Sir
