Page 413 of 529 FirstFirst ... 313363403409410411412413414415416417423463513 ... LastLast
Results 4,121 to 4,130 of 5286
    Sep 2017
    #4121
    errr... why is it important, sir?
    what does it matter if the tank is bolted to the chassis, or to the body sheet metal?
    Wala naman sir, nakita ko lang kanina kasi while naglilinis kaya napatanong na rin. Masyado lang kasi ako matanong, kuryus kung baga sir. Hehe. Anyway thank you sir!
    #4122
    Quote Originally Posted by PeterGChan View Post
    crawling underneath with a strong flashlight should do it, sir.
    i tried googling, and got nowhere.
    Sep 2017
    #4123
    Ai thank you so much sa trouble sir, appreciate it. Oo sir subokan ko bukas tingnan ulit, kanina kasi medyo pawisan na kaya di ko na tiningnan ng maayos. Mukhang mapasabak nanaman sa bagyo nga eto eh, sa amin daw direct path ni Basyang Sa Feb 13 tatama. Hehe. Thank you so much sir!2016 Toyota Fortuner
    Oct 2007
    #4124
    Hahahaha. Kasi kanina nag linis ako sa ilalim ng kotse, medyo nagulohan din ako kung nakasabit lang ba sa chassis or sa mismong body
    BTW sir, yung kulang lang talaga sa central lock natin is yung mag beep once pag nilock mo, tapos 2 beep pag unlock. Nasanay kasi ako na di tingnan ang ilaw or check kung open pa ang kotse after lock.
    Sir, sa akin may beep sound, once pag lock and twice if unlock.
    Sent from my ONEPLUS 5 using Tapatalk
    #4125
    manually checking each door by going around your car, is always a safe move.
    when a door lock mechanism fails, that is probably the only savory way you will find out.
    not all locking systems have an alarm for malfunction.
    Oct 2007
    #4126
    I've searched Google, meron nang discussion about the lock/unlock of the fortuner here in tsikot last April 2017, funny I didn't came across that discussion last year, anyway, they said it's in the owners manual page 185, yeah, yeah, I know what some of you will say, I should have read the owner's manual 2016 Toyota Fortuner
    #4127
    V models may tunog ang locking. Wala ata tunog ang mga G models.
    Sep 2017
    #4128
    Ahhhh ganon ba sir. Thanks sa info!
    Oct 2007
    #4129
    I followed what the owners manual said but it seems I can't get it to work, baka mali yung sequence ko?
    Sep 2017
    #4130
    Ano po ba ang balak mo sana ON sir na features? Same kaya ang owners manual sa G at V? Kasi sa page 185 ko about sa on/off sa lock features ata yun.
