Results 3,631 to 3,640 of 5286
November 4th, 2017 10:44 AM #3631
I always leave my lights at park... that way the headlight won't turn on in the morning.
Here are the steps to adjust your headlight sensitivity... set it to -40 for least sensitivity. I have tried this and it works.
Adjusting Fortuner V Headlight Sensitivity
1) switch ignition to on
2) make sure dimmer switch is in lowbeam and not pushed forward into constant high beam
3) turn light switch onto parker setting
4) turn ignition off
5)Hold headlights into highbeam
6)While highbeam is pulled on, turn to headlight than back to parker (not auto) 5 times
7)Release high beam.
The headlamps will flash in relation to what setting they are currently set on. It should flash 3 times with the setting being 0.
If they don't flash you are not in the settings.
8) Hold highbeam on again and turn between headlight and parker setting.
The number of times you turn it will vary the sensitivity.
Once -40
Twice -20
Three 0
Four +20
Five +40
9) Once you have turned between headlamps and parker for your desired preference release the highbeam.
The headlamps will flash for the number that you have selected.
And once it flashes say once, you are all completeLast edited by Monseratto; November 4th, 2017 at 10:50 AM.
November 4th, 2017 10:58 AM #3632
Do you need to adjust the opening height of your power tailgate on your Fort V?
Same steps...
- Aug 2017
- 50
November 4th, 2017 12:59 PM #3633
- Sep 2010
- 14
November 8th, 2017 07:26 PM #3634Good day mga Sirs. New V owner din and may mga inquiries lang ako.
1. Wala ba talaga beep or alarm pag nagre-reverse? Not related sa backup sensor ha.
2. With regards naman sa sensors, pwede kaya hinaan yung sound? (nakakagulat pag may nade-detect e)
3. Also noticed na maski naka-P (park gear) na e active pa rin yung mga sensors
Salamat
- Nov 2017
- 1,748
November 8th, 2017 10:34 PM #3635answers for number 1. - no sound on reverse (alam ko sa mga truck lang yun). me beep beep sound pag me nadetect sya obstruction sa aatrasan nya. and for 2&3 - pwede mo switch off yung backup sensor meron switch yun ktabi nung tailgate power off&on. Para disengage sya. Sna makatulong po eto sa inyo. Congrats for happy new fort owner.
- Jan 2008
- 4,726
November 8th, 2017 11:10 PM #3636
November 9th, 2017 03:34 PM #3637
What were you expecting? ... the musical sound like what they have in trucks when reversing? ...
- Nov 2017
- 1,748
November 9th, 2017 03:35 PM #3638
November 9th, 2017 03:38 PM #3639
I get what you mean for point 1. My in-laws' Innova has a beeping sound when you shift to reverse (they do not have a back-up sensor).
I guess it's just to remind you that you've shifted into that gear.
- Sep 2010
- 14
November 9th, 2017 05:36 PM #3640Yes, that's what I mean, yung beep sound (sa loob lang ha, hindi sa labas) once mag-shift sa reverse, meron din sa Altis e.
And was also hoping na pwede hinaan lang yung sensor alarm instead na i-off yung mismong alarm. Sa Altis tolerable yung sound level kaya pwede stay on maski nasa heavy traffic. Sa Fortuner nakakagulat e. Will also check sa casa if pwede disable automatically na yung sensor pag naka-Park gear na. Salamat sa inputs.
