Results 2,771 to 2,780 of 5286
June 27th, 2017 01:28 PM #2771
- Aug 2013
- 262
June 27th, 2017 02:57 PM #2772I just read about the bad reputation of Toyota Alabang. The thread started way back 2008 & come alive again today. There are so much bad reviews. They even featured in Inquirer. They've transferred to different location but some testify it's the same old kind of service. It's your job now to find out.
- Aug 2013
- 262
June 27th, 2017 03:04 PM #2773
June 27th, 2017 03:38 PM #2774
Dapat full stop and then set to N and then handbrake and release your foot sa brake, you will feel the fortuner will settle or move a little and then step on the foot brake again for added safety then shift to P and then engine off, hay daming gagawin...anak ng
Sent from my S7 Edge
June 27th, 2017 03:44 PM #2775
engine off then P?
thats just absurd. no person should follow this. (no offense)
- Aug 2013
- 262
June 27th, 2017 04:25 PM #2776
- Aug 2013
- 262
June 27th, 2017 04:30 PM #2777
June 27th, 2017 04:41 PM #2778
- Jun 2017
- 70
- Jun 2017
- 1
June 28th, 2017 08:21 AM #2780Not sure if the issue of the headlight sensitivity has been answered in the previous posts but this certainly worked, just tried it this morning, came form an Australian forum...
So don't be upset if you don't get it the first time.
1) switch ignition to on
2) make sure dimmer switch is in lowbeam and not pushed forward into constant high beam
3) turn light switch onto parker setting
4) turn ignition off
5)Hold headlights into highbeam
6)While highbeam is pulled on, turn to headlight than back to parker ( not auto) 5 times
7)Release high beam
( the headlamps will flash in relation to what setting they are currently set on. It should flash 3 times with the setting being 0 )( if they don't flash you and not in the settings.)
8) Hold highbeam on again and turn between headlight and parker setting.
The number of times you turn it will vary the sensitivity.
Once -40
Twice -20
Three 0
Four +20
Five +40
9) Once you have turned between headlamps and parker for your desired preference release the highbeam.
The headlamps will flash for the number that you have selected.
And once it flashes say once, you are all complete
For minimum/daily wage earners, sayang yung extra day. Last night in the news there was one would...
Traffic!
