Page 483 of 529 FirstFirst ... 383433473479480481482483484485486487493 ... LastLast
Results 4,821 to 4,830 of 5286
    #4821
    Quote Originally Posted by troydl View Post
    guys just a question. new fortuner owner here. how do i open the coolant cap? was checking and it wont rotate because it has some sort of “lock” to prevent rotation. i didnt want to just pop it off and couldnt find instructions in the manual... any video showing me how to do this will do fine also
    Talaga? Pagbukas lang ng coolant cap di ka marunong?
    2016 Toyota Fortuner
    #4822
    tekateka...
    if your radiator is similar to mine (and i believe it is, based on google), wala talagang radiator cap ang radiator na yan.
    what it has, is a white plastic overflow cannister beside it. this white thingee is the one that has a filler cap.
    medyo matigas pihitin, sa taong nag-aalangan kung maaari ngang pihitin siya o hindi.
    'di ba, may sticker sa taas na nagsasabing "do not open when hot" ?
    napipihit po yon. i have done it myself, several times.
    on the wall of the cannister, are high and low marks. we are supposed to keep the coolant level between those marks. "add coolant as needed."
    be warned that the other plastic cannisters there are NOT for coolant. look for the one that is connected to the radiator via a rubber hose. that's the one.
    the howner's manual should show what these various plastic cannisters are. they are designed for DIY servicing by the average car owner.
    if you can't find your manual, google them, sir. "fortuner engine bay".
    so, what are those structures on the radiator?
    grouse if i know.
    good luck.
    #4823
    What is the Part Number for the Oil Filter for our Fortuner? Vic Oil Filter usually are offered and I have read somewhere to consider others....Parehas lang ba yung oil filer for Gas and for Diesel?
    #4824
    Quote Originally Posted by ;3044435
    he's obviously a newbie to the vehicle, and asking for help, po.
    sabi nga ni eddie, "kapag kinulang, tulungan!"
    #4825
    Mga sir goodeve po. Sa mga MT users po, may naka experience na po ba na parang na cho-choke ung pag accelerate pag nasa third geard onwards? Ganun po kasi ung experience ko since last week sa forty ko. Thanks in advance po.
    Sent from my Redmi Note 6 Pro using Tapatalk
    #4826
    Quote Originally Posted by chenneth View Post
    when was the last oil change? when was the last air filter cleaning done?
    #4827
    sometimes, the engine doesn't like to be pushed, and it makes its displeasure known in this manner.
    it can happen when it is in an improper gear, or when going up an incline.
    it can also happen, if the engine's ignition timing is flawed.
    observe it, po, to see if it recurs more frequently.
    #4828
    Iniisip ko po kung sa injector na ba siya or sa clutch po. Sa 3rd gear upward lang po nag occur. Nung 1st 50000 km ndi naman po ganun.
    #4829
    gasoline model or diesel?
    #4830
    Diesel po Sir.
