Results 4,821 to 4,830 of 5286
January 20th, 2019 11:39 AM #4821
- 52,700
January 20th, 2019 09:54 PM #4822tekateka...
if your radiator is similar to mine (and i believe it is, based on google), wala talagang radiator cap ang radiator na yan.
what it has, is a white plastic overflow cannister beside it. this white thingee is the one that has a filler cap.
medyo matigas pihitin, sa taong nag-aalangan kung maaari ngang pihitin siya o hindi.
'di ba, may sticker sa taas na nagsasabing "do not open when hot" ?
napipihit po yon. i have done it myself, several times.
on the wall of the cannister, are high and low marks. we are supposed to keep the coolant level between those marks. "add coolant as needed."
be warned that the other plastic cannisters there are NOT for coolant. look for the one that is connected to the radiator via a rubber hose. that's the one.
the howner's manual should show what these various plastic cannisters are. they are designed for DIY servicing by the average car owner.
if you can't find your manual, google them, sir. "fortuner engine bay".
so, what are those structures on the radiator?
grouse if i know.
good luck.Last edited by dr. d; January 20th, 2019 at 10:10 PM.
- Feb 2008
- 898
January 26th, 2019 12:09 PM #4823What is the Part Number for the Oil Filter for our Fortuner? Vic Oil Filter usually are offered and I have read somewhere to consider others....Parehas lang ba yung oil filer for Gas and for Diesel?
- 52,700
January 26th, 2019 12:32 PM #4824Originally Posted by ;3044435
sabi nga ni eddie, "kapag kinulang, tulungan!"Last edited by dr. d; January 26th, 2019 at 12:43 PM.
- Jan 2015
- 82
January 26th, 2019 11:37 PM #4825Mga sir goodeve po. Sa mga MT users po, may naka experience na po ba na parang na cho-choke ung pag accelerate pag nasa third geard onwards? Ganun po kasi ung experience ko since last week sa forty ko. Thanks in advance po.
Sent from my Redmi Note 6 Pro using Tapatalk
January 26th, 2019 11:44 PM #4826
- 52,700
January 26th, 2019 11:44 PM #4827sometimes, the engine doesn't like to be pushed, and it makes its displeasure known in this manner.
it can happen when it is in an improper gear, or when going up an incline.
it can also happen, if the engine's ignition timing is flawed.
observe it, po, to see if it recurs more frequently.
- Jan 2015
- 82
January 26th, 2019 11:51 PM #4828
- 52,700
- Jan 2015
- 82
January 26th, 2019 11:53 PM #4830
