Results 2,521 to 2,530 of 5286
- Aug 2013
- 262
May 9th, 2017 09:24 AM #2521
- May 2017
- 8
May 9th, 2017 06:58 PM #2523
Same also with my Fort 2.4V, parang tatalon whenever I shift from D to N, sabi ng Toyota dati its normal lng, they said something about the torque, sorry, I forgot the term they used.
Sent from my S7 Edge
May 9th, 2017 07:25 PM #2524
It's possible that the brakes are not being applied evenly ... most likely only the front brakes are biting ... hence the feeling that the vehicle is about to pounce ...
BANNED BANNED BANNED
- May 2017
- 210
May 9th, 2017 07:43 PM #2525From D make a full stop then N make sure to put a little pressure on stepping your brake before moving your shifter
- May 2017
- 8
May 10th, 2017 05:23 PM #2526
- Aug 2013
- 262
May 10th, 2017 06:07 PM #2527The stance issue really is consistently persistent, regardless of any measures/actions we're taking. If this happens to be an abnormal to Forts, then it needs to be addressed.
But I wanna ask po sana those technical people, though it seems harmless naman mechanically, what could be the impact or possible circumstance pag hinayaan lang po namin na ganito? TIA
May 10th, 2017 07:23 PM #2528May naka experience na po sainyo neto.. tuwing icacarwash sya tpos nagreverse ka tpos shinift mo na ulit sa park... nakahinto na lahat ng gulong except ung gulong sa likod sa kaliwa.. umiikot pa din tpos bigla hihinto rin after ilang seconds (maririnig nyo po sa video ung pag hinto nung umiikot)
- Oct 2010
- 17
May 11th, 2017 11:23 AM #2529can anyone suggest aftermarket coil springs and shocks to soften the ride of the fortuner? salamat in advance!
You just unregister the device where its currently installed.
National ID Law
