Results 21 to 30 of 35
April 30th, 2008 08:52 AM #21
walang problem sa hiway ang 1.3 bro. ako nga dati 4 kami sa XL na big body napapa takbo ko ng 120-125 sa nlex papunta baguio, wala pa sa top condition yun.
April 30th, 2008 08:53 AM #22
April 30th, 2008 08:56 AM #24
pag tumagal daw po ang 1.3 mas madaling masira ang makina compare sa 1.5? possible po ba ito?
April 30th, 2008 09:35 AM #25
April 30th, 2008 09:49 AM #26
siguro iniisip nung nagsabi sayo na mas madali masira yung 1.3 kasi underpowered sya lalo na pag madalas madami ang sakay mo, kumabaga mas stressed yung makina mo
- Jan 2008
- 4,726
April 30th, 2008 11:56 AM #271.3 engine and 1.5 engine have the same specifications except for the bore.. so if the question is a 1.5 engine will last longer than a 1.3 engine?? i don't think so because they have the same material used in production it is only the bore and cylinders were changed... my brother use a vios 1.3j for his work, he travels from manila to isabela every monday and come back by weekend and sometimes for almost everyday he travels from pampanga to manila back and forth..btw his trunk is loaded of heavy electronic equipment that it is so heavy that the suspension is depressed almost 4-inches despite that kind of situation and travel, he can still run the vios fully loaded up to 140kmh and the car is still in very good condition and the engine still runs smooth.. no smoke or anything..
Thank you!
