Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 106
    #61
    Quote Originally Posted by albert_b View Post
    I guess that should be possible... but you will have to re-route your new DRL (previously your park lights) to a main power instead of the partlight switch. Then your double contacts will serve as your park lights. Its possible and it can be done. Find a good electrician.
    sir question lang... saang main power kakabit yung parklight?
    kaya ba tap sa accessories yun? like if your gonna turn the key automatic on na kagad?
    parang gusto ko gawin din to. thanks
    #62
    Quote Originally Posted by Camgen6 View Post
    It is not the low beam itself but another set of very low wattage lightbulbs.
    Depends on the car. On the VW passat 100% sure it's the low beam itself. On other cars like the Lexus RX300 its' the high beam naman, I guess on some other models may dedicated DRL light.
    Passat Low Beam vs DRL mode (notice the bulb in use is the same)
    You can even open up the cluster, wala talagang ibang bulb for DRL, it's just a matter of controlling the voltage to the light.
    Oct 2005
    #63
    You're right, some models have dedicated DRL just like the USDM Camry.
    #64
    Quote Originally Posted by s_quilicot View Post
    mga tsikteers pde ko ba i-convert yung 5watts na park light (peanut bulb) ng altis ko as a DRL? then yung signal light ill replace it with 5/21 double contact na amber .. ok ba yun?
    Sir. It might be better if you look for the diagram for the OEM DRL. Possibly to replace the wiring harness and check your fusebox. If there is an extra for DRL, it may be possible to upgrade for DRL. If you know someone or website that have the complete parts catalog or workshop manual. You can search there.
    #65
    AFAIK, Canadian Corollas use their headlamps as DRL's. Don't know about the current model but past models used the high beam filament burning at less than full intensity.
    #66
    doc otep anung generation nung mga canadian corrola? 9th?
    Oct 2005
    #67
    Correction on the Camry. The DRL is the same bulb as the High beam. Pics of my Camry. DRL, Low beam and High beam.
    Aug 2005
    #68
    Sa mga bansa/lugar na nasa upper lattitudes typically require DRL for safety reasons. Imagine at 12:00 NN parang 4:00 or 5:00 PM kung ikukumpira sa atin.
    In some places in the US, requires na you turn on your headlights if you turn on your wipers.
    Jul 2006
    #69
    How is it that the DRL/high beam unit show different amounts of light? Two filaments ba yung bulb for those? Or is it just in the way the lights were photographed?
    #70
    mbeige,
    The DRL and highbeam use the same filament. But the DRL uses less power (typically 75%-80%).
    #71
    Even if most cars are not DRL-equipped I believe it is still a good idea to run with the low-beam headlight on specially during adverse weather and while on an undivided highway. Whenever I drive long distance having my low-beam lights on serves to warn oncoming vehicles and pedestrians of my approach.
    Jul 2013
    #72
    guys is it bad po ba kung mag sstart ng sasakyan na naka on yung DRL?
    or i-off ko muna DRL upon start?
    ^ sa amin wala na switch ang drl ng mga sasakyan namin (monty at fd) wala naman nagka-prob so far
    Jul 2013
    #74
    pag on palang sir naka ilaw na DRL nyo po? tapos pag start wala naman po problema sa battery po?
    Aug 2010
    #75
    Quote Originally Posted by RF02 View Post
    My DRLs are tapped on my accessory wirings, so pagstart ko palang meron na. No problem so far naman.
    Jan 2014
    #76
    Dba yung 2014 sportivo may DRL na?
    Jul 2013
    #77
    Quote Originally Posted by jhnkvn View Post
    copy thanks sir ^^
    ganun na nga bos. automatic sindi na iyong mga iyan kapag nasa "on" position na iyong susi.
    mag one year na by the end of the month iyong nasa fd (courtesy of gary q) and hindi pa naman namatay iyong battery maski tapos na iyong warranty ng batt (due for replacement na din pala siya hehe).
    Jun 2012
    #79
    ^^ Get a DRL with a timer delay. It will not turn on while starting.
    Jul 2013
    #80
    thanks sa info sir baludoy ^^
daytime running lights (DRL)
