Results 381 to 390 of 392
December 4th, 2017 04:54 PM #381
Kulang lang ang AFP ng gamit due to CORRUPTION but they are capable of operating even sophisticated equipments
I hope your brain can absorb that
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; December 4th, 2017 at 04:57 PM.
- Oct 2006
- 5,692
December 4th, 2017 05:31 PM #382Nagbigay na ako ng scenario on how this plane can be used in CAS and recon mode mode para sa iyo. The Tucano has 6 hardpoints, you only need to use 1 (ok 2 para balanced) for recon gear, freeing up the other 4-5 for bombs/rockets, plus it still has 2 0.50in gunpods. Even if it has expended all ammo, an unarmed plane loitering over a battlefield is still deadly as it can be an artillery spotter.
December 4th, 2017 05:59 PM #383
I also gave u a scenario how to maximize the attack potential of a tucano
6 tucanos utilized as attack planes supported by a medium sized recon plane which can fly much higher and could stay airborne much longer than a tucano that were flown for recon mode
Against a 2-4 split for a recon-attack mode. While you alternate 2 tucanos every 2 hours for recon, you are left with 4 attack tucanos to rotate your bombing runs
Another scenario 6 tucanos with mixed load of surveillance suites and ordnance for attack mode and external fuel tanks for extended flight makes the operation of the tucano very complicated. Surveillance flight are simple flypast run..attack run are swooping maneuver. The more load an aircraft have the more sluggish it becomes
Which scenario would win the battle much quicker?
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; December 4th, 2017 at 06:05 PM.
- Oct 2006
- 5,692
December 4th, 2017 06:25 PM #384This thread got active all because of a silly misunderstanding of the Embraer announcement of "interdiction capabilities" of the Tucano.
- Mar 2005
- 354
December 4th, 2017 06:59 PM #385
December 4th, 2017 07:53 PM #386
Marawi conflict was resolved much sooner because the US lent us P3orion which is a dedicated surveillance aircraft.
That paved the way for the phil airforce to dedicate all its air assets (even the trainer aircrafts) to attack the mautes on the ground using the info provided by the P3orion
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; December 4th, 2017 at 08:00 PM.
December 5th, 2017 03:27 AM #387
o sige na nga, sabihin ko kay digong bukas bumili ng p3. para matahimik ka na.
pinagpilitan talaga e ano? parang natalo yata ito sa bidding.
- Nov 2017
- 1,748
- 52,727
December 7th, 2017 01:11 AM #390
