Results 11 to 17 of 17
December 15th, 2003 11:51 PM #11Originally posted by OTEP
Wiretap's body lift was around Php 5K, I think. His suspension lift was a more expensive.
Isang tanong pa ..... iba pa ba ang lift ng SUSPENSION at iba pa sa BODYLIFT ?? Tnx sa mga replies and hoipefully will finish it soon as possible , my decision would be a 2" lift and stick to the 30" tires and maybe a 275 / 75 ?? Malapit lang pala ako sa Calmini na factory , about 2 hrs drive located at Bakersfield . Tnx again ZUKI gods !!
December 15th, 2003 11:54 PM #12
In my own humble opinion, Filmar's does the best and most reasonably priced body lifts for the Vitara. You can go as much as 3inch body lift but I suggest that the maximum you go is 2 inches without the risk of straining your a/c lines, steering shaft, and extending your gear and transfercase shifters.
December 16th, 2003 12:03 AM #13Originally posted by DSM619
Tnx sa mga replies and hoipefully will finish it soon as possible , my decision would be a 2" lift and stick to the 30" tires and maybe a 275 / 75 ?? Malapit lang pala ako sa Calmini na factory , about 2 hrs drive located at Bakersfield . Tnx again ZUKI gods !!Last edited by Ungas; December 16th, 2003 at 12:12 AM.
December 17th, 2003 02:04 AM #14
Mali , 235/75 pala . Anyways ay ano ang the most you can comfortable fit na gulong na the more wier the better . Ayoko kasi na medyo napakalaki ng diameter kaso ang payat . Form over function lang ako unless it will bring to the direction in the future na install the upgraded gears , crawlers etc .
December 17th, 2003 12:38 PM #15
wiretap_md should be able to answer your query since he made lots of tire comparisons from his stock rims.
From my vantage point, my bet goes to 245/75R15, but I think most shops only sell 245 widths for 16 rims.
December 18th, 2003 02:01 AM #16
OK tnx . Yup , I have to stick to the 16 inch rims that came with it kasi aftermarket and maganda ang design as seen in the gallery under DSM619 , members rides . Salamat po ng marami .
December 21st, 2003 06:11 PM #17
dude,
update na lang on your upcoming mods, and post pics para may idea ako
thanks
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
