Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Mar 2004
    I do spray WD40 once in awhile sa mga in between bearings. It works though for me.
    That's not a good thing ...
    Mar 2018
    WD40 has no place in a continuously moving part. It's a short-term lubricant meant to dislodge stuck parts (ie. screws, tools, etc). Apart from this product being able to displace water and moisture, it is also a good degreaser. Spraying WD40 on bearings will actually dissolve or remove whatever lubrication it has. It might work for a while, but once the very thin film of WD40 dries up, the bearing will end up in a worse condition than before.
    Oh I'll take note of that. Thanks for the info.
    Feb 2017
    I also think it's one of the bearings. Pulleys to check would be the idler pulley, alternator, water pump, and power steering pump (if not EPS).
    When the A/C compressor runs, does the noise increase, decrease/disappear, or stays the same?
    Sir oj, it only happens when all accessory including the AC are off. When AC and fan are on it doesn't squeak. When the engine or the alternator makes a charging sound, it doesn't squeak.
    Sent from my SM-G532G using Tapatalk
    Sep 2012
    Quote Originally Posted by danegoesonline View Post
    sign ng maluwag na serpentine belt.
    did you have it checked sa casa?
    Pwede mo rin papalitan na yung belt nyan if 3 makita nila na may tama yung groves
    Feb 2017
    Quote Originally Posted by jodski View Post
    Pinacheck ko sa motech. hindi naman daw maluwag ung belt pero they didnt able to diagnose the issue kc that time wala ung noise. hindi ko pa alam na dapat patayin yung AC at fan para mag duplicate yung noise.
Suzuki Ciaz - what is this noise?
